TrainerRoad + Kickr + Stages config question
So my setup is a MacBook Air with BT4. I want to use the Kickr in ERG mode, the Stages for Cadence, and a Garmin Ant+ stick for use with a Garmin HR strap.
All was well for the first hour of the ride. I’d had a few spikes in the Kickr’s power with the laptop sitting about 3’ away from it. Then I realized that I had Bluetooth disabled and that everything was connected via Ant+. So I paused and re-enabled Bluetooth. That’s when the fun began… Seems like TrainerRoad would only talk to one of the BT devices at a time, not both. If I paired the Stages first, the Kickr didn’t pair and vice versa.
So what order or which BT and which Ant+ settings do I need so that I can use the Kickr in ERG with Stages providing cadence?
Review to come, but holy hell this setup is awesome.
Hi Alex,
There’s an issue pairing more than one Bluetooth power meter at a time right now on Mac. So I think if you try to pair both the kickr and stages via bluetooth, you’ll run into issues. You can still pair them both, but just pair one on ANT+ and one on Bluetooth. Or you can pair both on ANT+.
To get cadence from stages but power from the kickr, there’s a check box on the profile page called, “Use power from electronic trainer” that you’ll want to have checked.
Cool
Didn’t know that option existed
Looks like I can pull the ant+ speed/cadence off my TT bike :smiley:
