I’m finatical about having the exact same variables every time I get on the trainer (i.e. tire pressure, number of turns, even cleaning the trainer tire, and fan position…)Are your FTP numbers from Virtual Power, or from a PM?
Generally from Trainerroad, but I verify once in awhile with a Powertap. I like my virtual power to equal my powertap power. I’ve calibrated the trainer set up to match the powertap.
I am a bit confused. Why would you use virtual power instead of real power if you have real power available?
It’s not my Powertap…I have to borrow one from a close friend
Prob doesn’t want to use his race wheel…When I’m only on trainer in the “offseason”, i use trainerroad virtual power. Once i get outside, then I do a few hard rides to determine FTP on power meter.
In short, you can either ‘eyeball it’ which works fine with just a bit of experience.
You can use the various models in golden cheetah to model it for you. (2 parameter CP will tend to estimate a bit high, their new model that actually does a passable model of the entire curve is better)
I just eyeball it.
WKO4 will have a very nice model for this purpose as well. As long as you have some hard longer and hard shorter efforts it will figure out your FTP close enough.
Yes, I just look at power data, when I see records being broken in aerobic zones, I assume FTP has gone up a bit, and raise.
You can also look at your MMP curve and eyeball where the new FTP likely is
Jack - this is sort of what I have been doing as I hate formally testing. I don’t want to take time to make sure I’m properly rested.
How do you accurately raise FTP based on a power curve?
I just eyeball it.
One man’s hard is another man’s not so hard. The software can only use the data put into it. The software does not know how hard the athlete was trying. It will estimate FTP based on the data it sees regardless of how motivated the athlete was.
You need some verification of what constitutes a hard effort.
The software could easily estimate FTP as decreased based on the fact you were not trying as hard this month as you were last month.
I just increase/decrease the workout percentage depending on what my body is telling me that day. I always do everything possible before hitting the - button including suffering for a bit first to see if it’s just mental. There are however days where your legs are just blitzed from a tough run earlier in the day or from the day before. Similarly I always wait until 1 interval is complete to hit the + button as well.
I don’t believe these subtle changes are anything other than a better sleep or meal plan that day. For this reason I’d never forego the FTP testing protocol every 6th week. I ensure it is repeatable and as scientific as possible within reason (I’m not running a test lab) to ensure it’s tailored for me. Call me crazy but I really enjoy the buildup to getting on and doing the test and celebrating the results, good or bad afterwards.
I know a lot of people who don’t do FTP testing and I usually attribute it to
They are not detail oriented people, so creating a repeatable protocol for the 24 hours leading up to the test is a nuisance
They are “by feel” riders who don’t care about power figures
They have some other personal method to get their numbers
"As long as you have some hard longer and hard shorter efforts it will figure out your FTP close enough. "
hard being defined as, 99%+
It is of course up to the user to understand the context of their training. If you can’t do that, probably you don’t need to worry about your FTP anyway.
I don’t believe these subtle changes are anything other than a better sleep or meal plan that day.I agree. I can see big flucuations from day to day just based on my lack of sleep (newborn in the house).
I ensure it is repeatable and as scientific as possible within reason (I’m not running a test lab) to ensure it’s tailored for me.I fall in to this camp. I do my tests on the same stretch of road, at the same time of day, with the same amount of prep and try to keep my diet consistent.
But, I admit, I don’t do them as often as I should.
Those sufferfest videos are pretty tough so you are probably ok with what you are doing. Like someone else said. Be honest with yourself. Your plan seems pretty solid because you are incorprating some high IF 1 hour workouts to see where you are at. I would caution this plan generically because if someone were just base building they could be just pushing themselves up into a tempo zone and hurting their overall planning.
I don’t test real often but I will adjust based on hard efforts. I just did a 60 minute effort with NP 10 watts under FTP and I was able to sprint in the last 30 seconds. Based on this I bumped my FTP up a little. I find if I do allot of high IF workouts it is pretty clear when my FTP has risen.
So it will figure out your FTP provided you do near enough an all out effort. But how does the software know if the data was from a 100% effort, 99% effort or a 90% effort?
For that matter how do you know it was a 99% effort? I suppose when you look at the data you could write down a numner using a biro in a note book.
Well how about using a maximum 1 hr effort to determine FTP? How do you know it was maximum, or was it simply 98% effort? The fact is that all of your concerns are present for any good method to determine FTP.
Well if you don’t know if you have just done a 100% effort for a given duration you can never know your FTP by any method available.
The software does not know, you have to do provide it with the data. That data need not come from a formal test. Whether you do a formal test or not, you need to know how to go 100%. such is life.
I have been able to predict 1 hour power to within 3 watts without formally testing it for myself and others. It isn’t a big deal. I don’t even use the software I just eyeball it.
It doesn’t make sense to get hung up over 2-3 watts of accuracy on a thing that will vary 2-3 watts on a given day anyway.
Fortunately, if you select an estimated FTP value and it’s too optimistic, you’ll fail a lot of workouts pretty quickly and if you are smart - self correct.
Depends on what your training zones are… I would do a 2x20 @ FTP (trainerroad “Gray”) once in a while and that will tell you the truth.
Rather than do FTP tests, over the last few months I’ve been adding 5 ftp every 2-3 weeks…and it seems to be working really well via trainerroad. My protocol has been to add 5 FTP if I break records during two consecutive interval sessions which is usually in the 2-3 week window. For example, if my 10 minute power record jumps from X to X+5, and during the next interval workout that week my 2 minute power jumps from X to X+7 etc.
I was wondering if anyone else uses this method? and what your window for increase is? (i.e. every 10 days, 3 weeks etc.)
I haven’t hit a road block yet where I can’t complete the workout after an FTP increase but this may be due to the fact that I’m not running at the moment and focusing on biking for the first time in awhile.
Oh are you the guy who just trolls about using power all the time?
Sounds to me that if you do your FTP test at 95% of your max effort, then you’re not doing your FTP test correctly. Don’t blame the software, blame your weak and feeble constitution. Or turn your music up.
