Trainer functioning as ergometer? (other than CT)
Hey all -
Is there another trainer out there that functions as a programable ergometer (ala Computrainer) where I can program in a power/wattage and the resistance is automatically adjusted to keep me at that wattage?
thanks in advance
Don
Both the Tacx Fortius and Tacx Cosmos can do this as well.
thanks!
any others? and/or does anyone have any experience with the Tacx trainers?
I’ve used the tacx flow for a couple of years and the basic for about 5 years before that - no major probems.
Have not used the ergo function a lot but when I have it’s been okay. Has limits - for instance might not be able to generate some high loads at too low a cadence/wheel speed.
Tried renting a CT once and did not find the basic ergo functions to be materially different - of course, its possible that I just didn’t try a particular function that would have demonstrated why the CT was worth £1,200 more!
I have the Fortius. I got it when it 1st came out in the US, and they had a bit of growing pains getting it to work correctly with US voltage. They’ve gotten it about 98% perfect now and I absolutely love it. They only imperfection with how they got it to work in the US is that once you go above 26MPH on a flat road a “virtual headwind” kicks in to keep the trainer from overheating. My threshold work is only done at 22-23 MPH, so this doesn’t impact me there. If I want to do intervals above a certain wattage (that would exceed 26MPH), I just set it to a 1-2% grade. TACX has said that they will have a firmware update coming out to fix this eventually.
The trainer is great. I don’t use the virtual reality mode much. I use the Real Life Videos the most. They’re great. I’m training for the Roth Iron Distance race and I’m able to ride the course (with a video) during the cold Connecticut winters. Pretty awesome.
Where did you find the course video? Is it a Tacx disc?
I ride the virtual races alot. I’m also in the US and have a hard time keeping up with forgien riders on downhill sections (also I-magic v Fortius). I have to pedal at high wattage just to keep up at 33 mph. They are doing over 40 coasting the steep grades, so I like the flatter races better. This has to do with the difference in the electrical supply. Find that it pushes me easily to my upper limits.
The only RLV I have is Evergreen. Do you suggest a different one?
www.velodynesports.com
the velodyne looks great but no pricing info on the site. I assume this is probably NOT an economical alternative to a CT?
edit…found a pricing tab, but it only shows price for the classic model. Pro model must be higher, avanti lower.
The Roth course is from TACX and is their 1st “Ergovideo”. I also have Flanders, Mallorca, and the one with Galibier and Alpe d’ Huex (can’t think of their name for it). Mallorca is great for easier days, Flanders is really hard intervals, and the Galibier and Alpe are somewhere in-between. I don’t order them from the US retailers (way more expensive) but get them from TACX directly from their website (29.99 euros delivered, and they get here in approx. 10 days).
