Tour Magazine Tire Test Results
Thanks to John Z on the NYCC message board, here are results of the tire test in the latest issue of Tour Magazine.
Manufacturer, model, width x height, CRR at 35kph (85kg system weight, 7.5bar pressure), puncture resistance, wet adhesion, mounting
Clinchers/Tubeless:
Continental GP4Season 23.4x23mm 224g 53.90W 180s 33.20kph possible without tools
Continental GP4000s 23.4x22.8mm 207g 34.30W 180s 33.00kph possible without tools
Continental GP4000s TOUR - TEST WINNER
Hutchinson Fusion 2 23x22.7mm 233g 52.8W 56s 30.30kph with tools middle difficult
Hutchinson Fusion 2 Tubeless 21.9x20.5mm 299g 34.30W 41s 30.40kph with tools middle difficult
Michelin Pro²Grip 23.2x22mm 234g 43.70W 180s 32.60kph with tools easy
Michelin Pro²Grip Tour - Tip
Michelin Pro²Race 23.3x24.1mm 218g 36.00W 180s 30.30kph with tools easy
Schwalbe Stelvio Rain 23.6x23.2mm 215g 51.50W 180s 31.10kph possible without tools
Schwalbe Ultremo 22.5x21.2mm 196g 43.30W 180s 32.90kph possible without tools
Schwalbe Ultremo Tour - Tip
Vittoria Evo CX 23x22.7mm 229g 42.00W 9s 30.40kph with tools middle difficult
Zipp Tangente 21.5x18.9mm 204g 36.20W 47s 33.00kph possible without tools
Tubulars:
Continental GP4000s 22.3x19mm 246g 41.60W 180s 31.80kph inconspicuous
Schwalbe Stelvio 22.0x20.0mm 220g 47.00W 180s 32.90kph inconspicuous
Tufo Elite Ride 25 26.0x24.4mm 262g 41.20W 180s 30.20kph inconspicuous
Vittoria Evo CX 21.9x19mm 282g 41.10W 50s 30.60kph inconspicuous
Vredestein Fortezza Pro TriComp 22.7x21.6mm 278g 36.70W 6s 30.20kph inconspicuous
Zipp Tangente 21.5x19.5mm 269g 37.20W 70s 32.80kph inconspicuous
Keep in mind that different test laboratories and methodologies do yield varying CRR numbers.
Rating Criteria
Manufacturer, model, weight (10%), CRR (30%), puncture proofness (30%), wet grip (30%), overall grade
Clinchers/Tubeless:
Continental GP4Season 2.0 4.0 1.0 1.0 2.0
  • Gives good feedback. Soft transition to the adherence limit. Predictable.
  • Very good puncutre protection with dual Vectran breaker and firm sidewall. For rough roads. Wears square, rolls sluggish.
    Continental GP4000s 1.3 1.0 1.0 1.0 1.0
  • Rich riding impressions of a lot of rubber. Very secure, predictable. Besides the Ultremo the best riding experience.
  • Test winner. Optimal compromise between CRR, grip and puncture protection. Perfect all-arounder for training and competition. Thread wears square.
    Hutchinson Fusion 2 2.3 4.0 3.3 3.0 3.3
  • Soft riding impression. Predictable, but with a low adherence limit.
  • Thick thread made of three compounds. Sensitive despite of protection belt. Rolls sluggish. A tire without distinctive strengths.
    Hutchinson Fusion 2 Tubeless 2.3 1.0 3.3 3.0 2.4
  • Soft riding impression. Predictable, but with low adherence limit.
  • Tubeless tire for special rims. Construction and thinner thread allow for a much lower CRR than of the normal “Fusion”.
    Michelin Pro²Grip 2.3 2.3 1.0 1.0 1.5
  • Hard riding impression. Hobbles extremely. Hard to predict.
  • Competition and training tire. The CRR suffers under the improved grip. Wears very evenly.
    Michelin Pro²Race 1.67 1.33 1.00 3.00 1.8
  • Hard riding impression. Much grip on the shoulder, but less in the middle, stutters predictably.
  • Easily rolling competition tire with robust casing and good puncture protection. Wears evenly.
    Schwalbe Stelvio Rain 1.7 3.7 1.0 2.0 2.2
  • Hard to predict, doesn’t give any feedback. Slips away without stottering, tight limit range.
    Schwalbe Ultremo 1.0 2.3 1.0 1.0 1.4
  • Very good riding impression. Rich, predictable. Causes a feeling of much rubber on the road.
  • Very light competition tire with optimal adhesion and still good CRR. Wears very evenly.
    Vittoria Evo CX 2.0 2.3 4.7 3.0 3.2
  • Slips at a high, stutters at a slight sloping position. Unpredictable.
  • Rolls well, but other than that prooves itself problematic: bad puncture protection and delicate properties in the limit range make the Vittoria a good weather tire.
    Zipp Tangente 1.3 1.3 3.3 1.0 1.8
  • Gives early some very fine feedback, without stuttering. Only slightly worse than the GP 4000 S and the Ultremo.
  • The surprise. Except for the puncture protection a very good tire, grip and CRR within touching distance to the class winners. Relatively thin thread.
Tubulars:
Continental GP4000s 1.3 2.0 1.0 2.0 1.6
  • Predictable and of good nature. Reaches the limits a little sooner than the GP 4000 S.
  • Best tubular in the test. Flat and seamless construction with butyl tube. Does not reach the level of the 4000 S clincher: rolls worse, grips worse.
    Schwalbe Stelvio 1.0 3.0 1.0 1.0 1.6
  • Gives little feedback, but grips well.
  • Light, seamless tubular with butyl tube. Despite of a conventional rubber coompound very good grip. Thin thread. High CRR.
    Tufo Elite Ride 25 2.0 2.0 1.0 3.0 2.0
  • Mediates the feeling of much rubber. Limit announces itself. But pretty low grip level.
    Vittoria Evo CX 2.7 2.0 3.3 3.0 2.8
  • Unpredictable. Slips at a high, stutters at a slight sloping position.
  • Traditionally constructed, sewed tubular with latex tube and dual compound. Disappointing rgds grip and puncture protection.
    Vredestein Fortezza Pro TriComp 2.3 1.3 4.7 3.0 2.9
  • Does never mediate the impression of a secure grip.
  • Traditionally constructed with latex tube. Construction very similar to Vittoria, but more voluminous and faster. Disappointing in grip and puncture protection.
    Zipp Tangente 2.0 1.3 3.0 1.0 1.8
  • Gives early some fine feedback, secure feeling of much rubber.
  • Traditionally constructed tubular with latex tube. Single compound with good CRR and dimples. Only slightly falls back rgds puncture protection.
I didn’t know Continental made a GP4000s tubular and I can’t find it anywhere? Do you mean the Continental Competition tubular?
I don’t know. You could order it from Europe; do a Google search.
For now, I’m sticking with my M ProRace2s.
You can buy them here. Any local conti dealer can order them…
Its one thing to post a repeat thread when the original is buried, but THIS ONE is still on the front page…
Whoops!
I am to lazy to figure out and I value your opinion. Over a 40k distance and a 56 mile distance are Huthinson fusion 2 clinchers a good tire and how much time would it save me to go with a better tire over these distance’s? And if a better tire is in order which one in clincher for FP60’s?
Have asked locals and completed a google search the Conti 4000s in a 650. Does anyone know if it will be available in a 650?
Are you referring to this article?
http://tinyurl.com/7j8plw
It’s from 9/2007 - so it’s not completely current. I’m curious how the Michelin Pro 3 tires would have done if tested.
Dan
Dan
So is this post.
In Reply To Are you referring to this article?
Dan
So is this post.
Funny. Looks like someone a few posts above me randomly resurrected it. Although I still am curious how the Pro 3 would have scored… Ahh the mysteries of life.
Dan
Is it not current?
I would find the new Ultremos to be an amazing tire for racing and fast training…
I am not a Conti fan at all…but that is just me.
This thread and the information it refers to is OLD! Check the original post date.
and as long as they don’t change their testing procedure (i.e. stop testing different tire widths at the same air pressure), Tour magazine’s tests are pretty worthless.
Uh. I wish there were a summary.
Go for it!
Somebody please kill this thread.
