I did TI a year ago, and found it very worthwhile. I plan to take the course again next year as there are no swim coaches in this country, but I can fly to Singapore for a weekend for the course.
I found that the book is a little out of date with the way they currently teach, but that the dvd is very recent. If you want to try TI swimming out without spending on the course, order the DVD, which is about $30 and watch. Then go try some of the drills. It will at least give you an idea of what the system is about, and you’ll see how it goes together. If you then think that this is something that you want to try more of, consider the course.
J.
FQS is NOT catch-up. If it is, you are doing it wrong. Catch-up definitely makes you too flat in the water. It seems like a silly drill to me, except to possibly help with cross over.
FQS is what happens if you reach and roll your hips and shoulders. Your hands should not come close to touching. In FQS, as I see it, the reach and beginning of the catch are occurring as the opposite is recovering. Then, in one movement, the recovering arm passes the head and begins to enter the water simultaneous with the rolling torso, which secondarily completes the catch, vertical forearm/high elbow and pull. The two hands are going in opposite directions, and shouldn’t be anywhere near each other, other than that they are both briefly ahead of the swimmer at the same time. Hence FQS.
Watch videos of Thorpe or Hackett, especially from above.
PS. I DO NOT have any relationship with TI.
I may not have said this correctly and see what you mean about FQS being any time both hands are ahead of the head. This as opposed to catchup drill where the object of the drill is to nearly or very nearly touch hands at the top of the stroke definitely makes you go flat in the water. Thanks for the clarification it’s basically what I am aiming for but didn’t have the background to explain properly. Now I need to get our one masters coach to convince the one still doing the catchup drills to stop.
