A friend recently gave me a carbon-railed Selle Italia SLR Kit Carbonio saddle to me. I was told to be careful not to overtighten the bolts. Problem is, I’m not sure how hard I should tighten the bolts. The little manual that came with the saddle does not have any torque specifications. Can someone give me an idea how tight (in nm) I should tighten the bolts with my torque wrench?
Thanks for your help!
Bolt torque should be based on a variety of things:
- material properties of the bolt (strength, ductility)
- the application (shear or tension fitting)
- the material properties of what is being clamped (strength ductility)
- the geomety what is being clamped (thickness)
- the size of the bolt (diameter)
Without knowing the above, you are merely guessing. If anyone specifies an actual # for you, it’s just pulled out of the air with no basis. Attaching a seat to a post is a shear fitting situation - you need enough torque preload to give a nice clamping force and consequently friction force to prevent fore-aft slipping of the seat. I personally go by feel. I’m a little cautious with carbon, so I tend to be conservative and undertorque. I’ll carry an allen wrench so if I get some slipping, I know to torque a little more.
