Tom D. why'd you switch from Easton to VisionTech?
Tom,
I see that on your Kiwi ride you used an Easton aerobar setup. Just curious why you switched. I know you now swear by FSA’s aerobar line.
Jimmy
I switched because I think FSA Visiontech’s are better than Easton’s. Here’s why: Less Expensive. Can be cut to length. Greater adjustability when used as clip-on aerobar/seperate base bar. Much less complex brake lever system. Can be used with any brake lever.
That pretty much does it. The Eastons are very good- the FSA Visontechs are much better. I think they are the best aerobars available along with HED.
For the inside scoop, both these aero bars and a few others were tested in a wind tunnel. The results are available on Kraig Willet’s pay site.
http://www.biketechreview.com/
Jimmy,
I haven’t read anything conclusive with positive comments about the Easton bars. In '04 I was contemplating going from Profile to VT (which I did) and based it largely on this correspondence which you may find helpful:
http://personalbestnutrition.com/cgi-bin/forum/YaBB.cgi?board=news;action=display;num=1095074925
