Tom D...Leveling a Fizik Arione saddle?
I want to level my Fizik Arione saddle. Should the level rest on the flat front 2/3’s of the saddle only or across the whole length of the saddle. The method used greatly effects the position. It would appear by placing the level across the whole saddle the tip is higher than if you only level the front 2/3’s.
I hope this makes sense!
I would use the front nose section of the saddle and level that. The aft really scoops up.
