This keeps biting my in the hip and I need to do something about it. Whenever I race, my left hip flexor becomes toasted. It hurts and I have to stretch it out. At IMFL, after Mile 70, I could barely get in the aero position and hold it. This happens in longer distance races like HIM and IMs, but I’ve had it happen in Oly’s as well. It’s always the left hip flexor and I also usually have lower back pain on the left side as well. This rarely happens in training, too.
Anyone have any clue as to what could be wrong and what I could do to fix it?
I suffer from this sometimes as well. From what I have read tight hip flexors and related muscle groups are really common for runners and cyclists. I’m trying to be more diligent in my stretching.
Have been using a stretch as follows: lie on back, cross right ankle over in front of left knee with both knees bent as though you are sitting with legs crossed, pull on right knee with right hand to stretch right hip, reverse for other side. Wish I had a photo, sorry.
I think lots of things can cause this and it is not possible to know just from a description on a forum. However, whatever the root cause, the proximate cause is most likely that your muscular usage is not balanced.
If you are unbalanced one fix, if it is fixable, would be PowerCranks.
It’s always worrisome when something goes wrong in racing that doesn’t rear its head in training. Improving the conditioning of the muscle, as Frank said, is one way to go. PCs would certainly do that.
However, I would still try to focus my training rides on race-like conditions. Perhaps it is swimming first that sets it off? Maybe you need more kick sets, or some work on body balance in the water. Are your training rides having you spend long, unbroken stretches in the aerobars? Some people are up-and-down a lot on training rides, and the fixed, steady nature of racing causes unexpected problems. Maybe you need to be more diligent in training to stay in the bars…?
Anyway, I would try to elicit the problem in training a few times.
I think you are right in the fact that I’m not in my aerobars for long stretches in training. Riding around Austin just doesn’t allow that much. I do think it’s a muscle imbalance issue as well because I know that I’m very right leg dominant.
Try a lot of single leg drills–5 minutes X 2 sets each leg, high resistance, low cadence, OR 5X1 min each leg, high cadence, lower resistance.
I’m also VERY right side dominant. On training rides I try to remember to do a lot of long stretches where I concentrate on my left leg and try to ignore the right. that’s both in TT and climbing rides.
There must be someplace where you can ride, away from traffic and stay in aero for long stretches. Parks, around lakes…
A tight psoas can feel like a hip flexor issue. There is a good chance that if you are hunched over for a long peroid of time, your psoas is going to contract. since it connects to your femur and in your mid-back, it would also explain your back pain as well.
The psoas (as part of the iliopsoas) is a major hip flexor isn’t it?
The question it seems to me that you ought to be asking, if you are doing all these drills, is: Why do you remain “VERY right side dominant”? In other words, why do you give these drills as a way to correct the problem when they seemingly haven’t corrected it in you?
I have always been VERY right side dominant. I think I likely have a little hemihypertrophy. My right lower extremity is slighly longer than the left. Both right sided extremities are larger than the left, despite years of doing extra reps in the weight room on the left side. Years of tennis probably didn’t help things in that regard. It doesn’t bother me or cause me any discomfort. I just recognize that I have this propensity and try to do extra everything with the left to compensate.
well, it hasn’t helped significantly. It shows you how hard it is to correct these imbalances in aerobic strength in the gym. PC’s should have it almost totally corrected in 2 months.
I don’t doubt it, but my wife will kill me if I spend anymore money on equipment right now. I was a PM, too. Gonna have to wait. she can’t understand what a 55 year old is doing racing triathlons anyway. But, I’m having a blast and I’m pretty competetive, so…
BTW. I do the Single leg stuff in aero as long as I can, then I switch to the horns and finally the pads for each repeat set, then I go back to aero for the next repeat, to start. It is NOT fun, but it gets better each time.
The back pain is probably your psoas screaming. It originates up along the lumbar spine.
I do a decent amount of single leg drills. I really don’t have a problem with doing them, though. I guess PC’s would work but I’m also saving up for a power meter as well. I’ll try doing one leg drills in an aero position.
I’ve noticed this same phenomenon in some 1/2 IMs. It starts cropping up toward the end of the swim for me. As others have pointed out, ask yourself what is different on race day. The big thing I came up with was swimming in a wetsuit, which definitely restricts your range of motion. I’ve experimented with limiting swim kicking intensity and had success without losing much if any time. I was usually able to work out the tightness once I got out of the water, so for me I’m pretty sure the hip tightness was related to the swim.
