Titanium Aerobars
http://www.aero-concepts.com/
Unusual bars, could be nice for the titanium obsessed, which includes me. Not sure what the cost will be.
Very cool, and I agree, the price could be the kicker.
It looks cool but it says “fully adjustable” in the description and the picture (It says prototype on it so there may be changes) looks like the whole thing is welded together which wouldn’t provided much adjustability. I wonder how the price will compare with the cool carbon.
Allan, I bet inthe $600.00 plus range, that’s the kicker!
It’s probably in the brackets for the arm rests that help with adjustability.
I am going to test a set for the bike blog as soon as I get set up on a new bike.
I think they will compare favourably to the price of carbon, according to my conversation with Steve.
looks like the extensions slip into the base bar which will allow adjustability. (similar to the Ovals).
notice they don’t talk about weight?
I don’t think Steve wants to talk weight as the final production samples have to come. I think he’s being responsible NOT talking weight until he has consistent production samples.
lt looks better in that view than this:
http://www.cyclingnews.com/photos/2005/tech/news/apr05/Picture028tn.jpg
Kind of looks like a lawn aireator fork from this view!
Well, here is a question about the photo above: what is the point of suspending the elbow supports above the bar?
Clearly the elbow supports will be adjustable for width, but why couldn’t the mounting of the pads be directly on to the base bar? The suspended brackets are so low that there is no way a rider could you use the space below them (say, for putting his hands), so what is the point?
And that, I suppose, is the sole reason to buy these? Does titanium offer any benefit at all in an aero bar?
A very good question, and one that I am not qualified to answer, sorry.
this has been talked about in a few other threads
I posted about the CAD drawing he has up on his site - it looks like the base bar is oval and not “aero” - IMHO is a bit of an oversight because you are looking at an integrated bar to “be more integrated” and hence assume it will be more aero (as discussed in Tom D’s article on the Bikesportmichigan site)…Personally, I dont know why you would use a simple oval cross section except to increase weight (!)…of course the CAD drawing may not be 100% accurate…
as for increased durability - again I look at this like I would a comparison between ti, carbon and al bike frames - its so much about material properties as much as the design and fit/finish/manufacturing/weld quaility…
Interesting but Im not sure why someone would go to this as opposed to say a visiontech, Hed, Oval, for aeroness and say a profile for adjustability…other than perhaps a Ti fetish…
my 2 cents…
$399.99 is the price. I may consider a pair, just to be different and satisfy my titanium obessession.
WOW! Super price. I may join you after I see how others like them.
Jack
Sure, Ti isn’t going to be as light as carbon; but maybe it could.
Ti could be a great material for a handlebar, and considering how much sweat we can produce, it will certainly be more durable than aluminium. Impact resistance will certainly be higher, as the handlebar does take considerable abuse. Nick a CF or aluminium bar deeply enough and you have to replace either. Yes, you can repair CF (I have made many, many repairs on CF), but on a handlebar, it could be a risky proposition.
You are right, it all depends on construction, but on an item like a ti bar, if properly constructed, it would last a hell of a lot longer than a similar one in carbon or aluminium. One should really replace aluminium basebars and stems every few years because of the stresses that a stem and handlebar can take, both from the rider, corrosion potential, scratches, and the like. Carbon would last longer from the standpoint of not having age-related effects, and would hold up for all of the reasons (provided galvanic corrosion would not attack the aluminium parts, and gatorade or sweat can have enough electrolyte to induce this if not properly treated) I said aluminium won’t, but then you have the impact factor. There is a very, very good reason why Steve is going to back up this bar for a long period of time.
Weight for ti- if it is the right alloy, ti is not nearly as heavy as you would think. I have not a clue what alloy Steve is using, but 6/4 can be scary light as the walls of the tubing can be like the thickness of tissue paper with great strength and stiffness characteristics. I also have come to the conclusion that maybe the handlebar and stem is not the right place to save weight.
As far as the shape goes, nine out of ten of the riders won’t be fast enough for the shape to even matter; though in my interview with John Cobb (really, really nice guy and smart as a whip, to boot) does say that aero helps at every speed. I will say why in my article. But oval is certainly better than round, airfoil is best, and I have a sneaking suspicion that Steve has that under control. Oval shapes make for a better welded bond for the handles and stem, as well. But even airfoil shapes in a cross section drawing look like an oval. I will say when I get this bar.
I think that this bar is going to be a surprise big hit. I am going to test one very soon. Why I think so is that:
a) The Profile integrated bar is quite dated
b) VT does not have any adjustability
c) Hed and Oval bars are nearly the same bar, and there are some usability factors that need to be worked out, particularly in the cowhorn shapes (the inability to cleanly tape the bar; can you say “aero at any cost?”), and again are dated designs
d) the other bars are either waaay to expensive or the designs fall short in usability and adjustability
e) Integrated Ti bars were a bespoke item that only people with very deep pockets could afford
Not trying to be rude, but I think you had wanted to say something after your quote.
What did you have to say about “But oval is certainly better than round, airfoil is best, and I have a sneaking suspicion that Steve has that under control. Oval shapes make for a better welded bond for the handles and stem, as well. But even airfoil shapes in a cross section drawing look like an oval.”?
I want to look over the drawing so I won’t make a total ass of myself.
I stand corrected- it IS, infact an oval in the drawings. No way around it.
Who knows? Maybe an airfoil was too hard to do in ti.
But like I said, an oval is better than round, an airfoil is best.
bunnyman, so what do you think is the point of suspending the elbow supports above the bar? Clearly the elbow supports will be adjustable for width, but why couldn’t the mounting of the pads be directly on to the base bar? The suspended brackets are so low that there is no way a rider could you use the space below them (say, for putting his hands), so what is the point?
