TitanFlex beams
Can anyone tell me the tube diameter and wall thickness of a “Mocha” model, TitanFlex titanium beam. I weigh aprox. 165 lbs so that would be the appropriate beam. However, I will be using the tubing in an unconventional way.
P.S. If you have the dimensions of a “rocky road” that would work as well. It just wouldn’t flex as much; Unless I cut it much longer!
Thanks everyone
rlong, I don’t know if the dimensions are different between the booms. In fact, I’m sure the outer dimensions are the same, it’s the wall thickness that changes. Just email Tom at TitanFlex, I imagine he’ll tell you. Or, I can put a tape measure around mine later today.
The outer diameter is just over 28 mm or just under 1 1/8 inches.
Thanks for your help.
Thanks AJ
