Just some reading material;
We heard the buzz about a surprising new tire test in Bicycle Quarterly, a
nifty magazine published in Seattle and edited by Jan Heine. The name was
Vintage Bicycle Quarterly until recently, but “vintage” has been axed
because it implied the mag was about old, collectible bikes and equipment.
Well, plenty of pages are devoted to arcane and interesting gear, history
and randonneur-style riding, but Bicycle Quarterly also publishes
cutting-edge material. The tire test is testimony, appearing in the Autumn
2006 issue.
Heine gave RBR permission to summarize several major findings.
Interestingly, they confirm lots of what Uncle Al has been ranting about
for years regarding tire width and inflation pressure.
Some test conclusions will be particularly enlightening if you’re riding on
narrow, high-pressure clinchers seeking more speed via lower rolling
resistance. Your skinny tires may not be as fast as you think.
For the full eight-page report on tire performance, order the Vol. 5 No. 1
issue from http://www.bicyclequarterly.com. The test included nine 700C
tires, seven 650B tires and two tubulars. The protocol and results were
reviewed by industry experts. These are eight findings:
—With roughly the same power output, the rider’s speed can vary by as
much as 20% depending on tire choice. For example, the rider on the fastest
tire moved down the road at approximately 16.4 mph
(26.2 kph) while the same rider on the slowest tire went approximately 13.6
mph (21.7 kph).
—Many longtime riders believe tires with a cotton casing are faster than
modern casings made from nylon. Testing seems to confirm this. The
best-performing tire in the test, the Deda Tre Giro d’Italia 700x23C
(actual width 24.5 mm), has a cotton casing.
—Tire pressure has only a small effect on the rolling resistance of most
tires. Narrow 23-mm tires seem to roll fastest at pressures of 105 psi (7.2
bar) or more. However, running these tires at 85 psi (5.8 bar) for improved
comfort increased the test times only 2%. Wider 28-mm tires are as fast at
85 psi as they are at higher pressures.
—Tubular tires perform worse at very high pressure. At 130 psi (9 bar),
the narrow Clement Criterium rolled slower than it did at a more
comfortable 105 psi. The wider Clement Campione del Mundo rolled slightly
faster at 85 psi than at 105 psi.
—Wide tires do not roll slower at lower pressures. In fact, testing
indicated that a wide tire at lower pressures rolls faster than a narrow
tire at high pressures, if all other factors remain the same. Even narrow
tires can be ridden at comfortable pressures with only very small
concessions to performance.
—Tires rolled slightly slower with Michelin’s relatively thick latex
tubes than with butyl tubes. Thinner latex tubes, like used in tubular
tires, may offer better performance, but when used in clinchers they are
more prone to punctures caused by friction between tire and tube. Latex
tubes do improve comfort.
—Perhaps the most important result of the test is that tire pressure does
not significantly affect rolling resistance. Wide tires in particular do
not need high pressures to roll fast. But because many current wide tires
are designed to handle high pressure, they have strong casings that lack
suppleness. This results in higher rolling resistance than necessary.
—The test’s findings point to a new direction for performance bicycles.
For most cyclists, wide, supple tires at low pressures offer more speed,
better comfort, increased versatility and improved safety than today’s
narrow high-pressure tires. However, this type of wide, fast tire currently
is not available. Hopefully, these test results will help persuade
manufacturers to produce them.
