I think this is kind of a useless question, but it’s been nagging at me a bit and I can’t decide so I though, what the heck - I’ll ask here to see if anyone has any info that could sway me one way or the other.
Real quick background - I come from a pure cycling background of 20+ years now and have used a HR monitor in the past (Polar) but after a while I pretty much knew my HR purely based on my perceived effort…then the Polar broke and I decided not to replace it. A few years out of competitive racing due to back problems (which I think I may have solved enough to lightly compete again), I’ve decided to start some training and looking into doing some short tris next year (mainly sprints to start but wanting to try some Olympic or half’s).
I’ve been cycling, started swimming a few months ago and this week started to incorporate some running as well - right now just to get some base established in swimming and running which are my weaker points. I’ll work on more structured plan in time.
Now my question is, Initially I was planning on picking up a Garmin 705 for my bike, but now that I’m swimming and running a bit, the 705 becomes pretty useless off the bike so I was looking at the Polar RS800CX Multi which incorporates all three disciplines and looks to have almost all the functionality of the Garmin 705 without the GPS maps…but there are also a lot of functions on the RS800 that I would probably never use. So, then I thought what about the Garmin 705 for the bike and just a Timex Ironman watch that I could use as a lap counter in the pool, splits and other simple functions (but no HR monitor).
Price ends up being close enough for either choice that it’s a wash. Thoughts? Am I missing anything obvious? For those with some equipment experience - what would be your choice? (and don’t say both as I’m not willing to drop the $$ on both units just now.)
I have to answer with the ubiquitous “It depends” on how you are going to use it. If you frequently ride on new routes and need the Garmin to tell you where to go, the Polar can not do that. I have an old Garmin Etrex Legend that I use for this purpose, and only mount it on the bike when I am riding away from home or on an unfamiliar route. Still, this is a low proportion of the time I spend training. You can get these on ebay for under $100. I don’t have the Garmin 705, so I don’t knwo really what it can do that the RS800 can’t but I have the RS800CX with the GPS sensor (I forget which package they market this as). I love it, as;
I can use it on open water swims, but it won’t give a straight line due to no reception under water, so I upload the tracks to google earth, then measure lines from the corners to get rough distance. On the bike it keeps a good historical reference of my ride, with HR, Speed and elevation in one file. That being said, I still have a standard Cateye computer on the bike which I have mounted where I can see my real-time speed and cadence. On the run the instantaneous speed is not very accurate, but I use it to check my mile splits (autosplit function) and manually keep an eye on my 1/4 mile splits. All of the data ends up in one software package.
The negatives in my opinion are:
The heart rate monitor does not work in the water.
The multisport mode for switching from Swim to bike to run still has a long way to go really for use by triathletes. In a long race, it might be worth all the button pushing, but for a Int’l or less, it is too much. You should be able to set up a workout plan based on multiple sports as phases and ‘lap’ through them.
The software still has room to go, and Polar has been VERY SLOW with updates to the Polar Pro Trainer lately and the last one caused more new issues than it fixed.
There are still issues between zones in the software and zones in the hardware, and phases in the software plan and phases in the views on the watch.
The software does not have enough flexibilty to plan “pyramid” or “ladder” type workouts without running out of phases and going to multiple software workouts in one physical workout.
You can now combine excercises if you stop one, but no way to re-start a workout if you accidentally stop one.
As of now, I don’t know of any way to get the data into another software package other than offload it from the watch to the Polar Software, and then move it to Training Peaks, etc. Not sure if anybody else has adapted the IR code to bring the data straight into their own software.
All in all, I love my Polar, but it is far from perfect, and it depends on how you will use it.
Have you considered the Timex Bodylink. it’s modular. you can use just the watch for laps and timing. you can add the HRM when you want that data (doesn’t work in the water) and/or you can add the distance/speed when you want. And you have an ok all around watch so you don’t have to take it off / put it on for each work our. not bad.
good luck
good luck
Thanks, I’ll take a look
I highly recommend you read runtotri.blogspot.com. The author, Jan Musil, has had many high-end HRM’s, including the RS800CX. He has written an extensive review of it and about using it in a tri.
I have an RS800CX. It is a very capable product. It is one of the few HRM’s that measure R-R (google Firstbeat Athlete to read about that). It is hard to use. It has a steep learning curve. You have to read the instructions. The user interface is not intuitive. The IRDA interface sucks. I had an RS800 before that. The RS800 was hard to use. I thought the RS800CX would be easy to figure out since I did the learning on the previous watch but it wasn’t. I am doing my first tri on Sunday. I don’t think I will use it. I have a Garmin 705 and I will definitely use that; I love it and it is simple. Garmin products tend to be a lot simpler than Polar’s. I like getting my HR while swimming, even though most coaches recommend against that. The RS800CX won’t do that.
If you are going to consider the RS800CX, consider the Suunto T6C. It has its advantages and disadvantages (see Jan’s blog about that). It is easier to use in a triathlon.
