Timex Run Trainer Programming Help
I set my custom display settings, custom 1, to four lines and my choices. Now when I’m at the Chrono mode and everything is zero, how do I change it to my custom settings to view? I’ve messed with it for an hour and I can’t figure it out.
Technically challenged! Thanks
Bump - I’m going crazy. Maybe someone with the Global Trainer would work the same steps. HAAAA Technology. tough switching from a Garmin
So you are in the Performance mode and viewing the Swim w/ Swim split on top, and Swim lap on bottom and want to view the Custom 1?
No I’m in Chrono where I get the default view but I want to use my custom 1 view, which shows disance, pace, run time, and HR.
Go to timex and download the user manual?
two options: tap the Radio Back button (middle on the left side) to cycle through the screens or hold Select (middle right side) to see the display menu and check off the one you made.
I did download the manual. Written by some technogeek and I couldn’t find the “english” version to help me.
Thanks, I’ll give that a try tomorrow.
