Time Impact Pedal Clicking Noise
Has anyone got rid of the clicking noise from their Time Impact pedals? It’s got to the point were tri-flow doesn’t cut it anymore. I’m going nuts listening to the clicking!
Time to buy the new RXS pedals. I have them on two bikes and love them.
Dave in VA
Dave in VA
They’re on the list for next year. However I’ve promised myself (actually my wife) no new equipment this year. So I guess it’s tri-flow until next year!
If it is the impact, there was a batch of them that did not have a washer installed in them. If you take them apart and pack them with grease they are OK for a while, but they need the special little washer to solve the issue completely… However - they should have been clicking most of their life if this is the case…
They have clicked since I got them a couple of years ago. The click comes and goes. Tri-Flow on the spring and cleat sometimes does the trick. So this washer is missing from the axle? Were can I get this washer?
I had a mechanic do it - but I am pretty sure you need to get the washer from Time (so the shop where you bought them should sort getting one from Time). I think the washer goes next to the bearing (inside the pedal body, on the axel). The mechanic was grinding his teeth a little when he gave tham back to me - so I suspect it was a bit of a fiddly job! Mine was done under warranttee - no questions asked.
Thanks a lot. Maybe a new pair of RXS’s aren’t out of the question.
No worries - I still like them. They give a positive feel, and I was happy with the back-up I got. I think you should still try and 'rescue them if not too much hassle!
