All parts being equal, which would you rather have Ti or a Carbon road bike? I can get an insane deal on a new Ti road bike with better parts than a carbon. Just wondering if Ti is dead.
I don’t think Ti will ever be dead as long as there is elemental Ti available on the planet. It offers a very nice ride.
Chris
Ti is certainly not dead.
How long are you planning on keeping the bike. A ti bike could last you forever, carbon’s longevity hasn’t been (as) proven. Ti will stay looking great with less maintenance and/or care.
A choice between something like a QR Tiphoon and a Lucero is just a personal preference thing. Both bikes are great.
All parts being equal…take a visious spill on carbon - CRACK - frame done, catch a cab; meanwhile, Ti dented and repaired by able Ti worker or company…and probably be able o ride home.
I’ve seen more broken Ti frames than broken carbon frames.
Yeah, me to, but I put that down to carbon has only just become affordable to the masses. All the Ti frames were probably repairable…hopefully it wasn’t the same guy, every time!?
Not really. I’ve seen a lot more carbon frames on the road than Ti as well, since the LBS was a pretty big Trek dealer. Ti was never very popular in my neck of the woods.
Oh yeah, some carbons can be repaired good as new
For me…I prefer ti to carbon for these reasons…
Not as likely to be damaged in a crash.
No chipping paint or clearcoat when packing for travel.
To me they have about the same ride quality…but ti is much more durable.
My Serotta Legend Ti is approaching 12 years old. I plan on having it as my sole road bike for as long as I’m still riding a bike. Then I plan on giving it to my grandkids.
Broken how? Where?
Ti and carbon bikes of similar quality are probably quite close in durability. Although the glue/epoxy used to bond carbon tubes MAY deteriorate, whereas a ti weld won’t.
As mentioned, a scotch pad and some elbow grease with get a ti bike looking like new. New paint or clearcoat is needed for carbon.
It is probably easier to spot damage to a ti frame than a carbon frame.
“I’ve seen more broken Ti frames than broken carbon frames.”
It may depend on which Ti alloy is being used. 6/4 is much more brittle than 3/2.5 but is lighter and ‘stonger’ than 3/2.5. A few years ago there were ‘a lot’ of Litespeed Vortex frames cracking. The Vortex is made with 6/4. I don’t know if this is stll a problem with the Vortex. 3/2.5 is a bit heavier but is much more flexible. This is the alloy that typically gives the legendary “Ti ride.”
These were mostly 3/2.5 frames, some 6/4 frames as well. I don’t want to give specific brand names though.
Typically the break was caused by poor design (like a rivet resulting in a stress riser) or a fracture near a weld, indicating that the construction of the frame was poor. Ti can last forever, but it is very dependent on the expertise of the builder.
Are there different kinds of Ti that are better than others? The one I am looking at is Crafted from 3/2.5 straight gauge titanium tubing.
Most ti bikes are 3/2.5, some are 6/4 which is lighter, stronger, more brittle, harder to work with and therefore more expensive. Every once in a while you hear about cheap Russian or ‘commercial grade’ ti.
Ti is harder to work with, ie form, bend, weld, etc. So there is let butting or shaping of tubes. That is one of the great things about Litespeeds, they are experts with ti, and can form much more interesting tube shapes.
If you are going to spend the $ for ti, stick to well known brands, like Litespeed, QR, Merlin (sort of the same thing), Serotta, Seven, Moots, etc.
here`s a quick answer from tiger martin about my question about my blade a few months back.
Great questions all. The numerical designations used to differentiate
titanium alloys list the percentage of the alloying materials. In the
case
of ti frames these are aluminum and vanadium. Your Blade is made of both
of
the alloys we use: 6al/4v and 3al/2.5v. 3al/2.5v is the more common of
the
two and is easier (but not easy) to work. 6al/4v is much harder and
stronger, but also much harder to work. 6al/4v is expensive because it
takes
a lot more time and energy to manipulate it. Its advantage is that with
its
increased strength, you don’t need much of it to make a useable bicycle
tube, thus creating a tube of comparable strength to a 3al/2.5v tube but
without as much weight.
The down tube on many bicycle frames gets fatter near the bottom bracket
shell as a way to better brace the shell to resist the forces imparted
upon
it by a pedaling rider.
All the Best,
Tiger Martin
International Sales
American Bicycle Group
9308 Ooltewah Industrial Drive
Ooltewah, Tennessee
37363
USA
tiger.martin@americanbicyclegroup.com
www.americanbicyclegroup.com
(T) 423-238-5530 x253
(F) 423-238-4682
When I was driving down to Disney 70.3 last year, I had my Saber on a bike rack on my camper. Unbeknownst to me, a strap I was using to hold them down was rubbing against the chainstay, and it did it for the entire 11 hour drive. On a painted or carbon bike, there would have been an ugly bare spot, or at the least, a very scuffed finish. As it was, the ti just got a little bit shinier in that area, like it got a nice polish.
I’ve seen FAR more broken carbon frames than Ti frames.
For the record, I have a few of both.
Both are fine - if you can get an “insane” deal on the Ti bike, get it.
I just swapped out my Litespeed Vortex for a Cervelo Soloist Carbon. I liked the ride of the Vortex much better to be honest, but I’m faster (at least I think I am) on the Soloist (all things considered), but it is MUCH stiffer than the Vortex (good in a way - but not the smooth carbon ride of, say a Trek OCLV type bike). I guess it also depends what you plan on using the bike for: crits, road racing, touring, general training, etc. As others have mentioned, it depends upon the carbon bike a lot (layup, purpose, etc.). But in my experience, about all Ti bikes ride pretty nice, but all can be flexed some by strong riders (not an issue for me as #1 I’m not strong enough and #2 don’t care if the frame flexes some anyway - hence the comfort).
If you’re clumsy, get Ti.
My road bike fell over and landed on my trainer twice in one day. I think it also hit the workstand once. The only result was a messed up decal and some light scratches that Scotchbrite would fix.
I also had my bike storage stand let go after 2 years. My old Ti road bike was thrown across the living room onto the coffee table.
Any of those incidents would’ve at least done quite a bit of damage to the finish of a carbon fiber bike.
I recently bought my first carbon bike in 10 years though, a P3C. You can bet I’ll be a lot more careful with it. If I got a new Ti road frame, I would start beating on it from day 1.
