Was dialing my fit in for Whistler today on the new Speed Concept. I would definitely go lower for TTs or shorter races but this seemed very comfortable for long course. Sorry for the vertical video.
Crickets from the peanut gallery.
Looks pretty good, though I assume you’re not under power in the vid. Angle your forearms up about 5 or so degrees and you’ll lock yourself in a bit better and likely gain an aero advantage (likely because as we all know, testing is the only way to know).
Thanks Jim… The load was minimal there (under 150 watts). I was going to play with the tilt this week to find what was most comfortable.
Hi Pete. Are you in the 206? If so, who are you working with on your fit? And where did you get your Speed Concept?
Ps - your position looks great to my untrained eye!
Scott
