So, Ive got it in my mind, to make a Trimble type of bike.
Possibilities:
a water bladder inside the main triangle
All internal cable routing
front wheel fairing
small fairing for the FD
fairing behind the stem
Something like:
Ofcourse I wouldnt use a Principia or any other nice bike for this, instead, some other cheap tri bike something like:
Supposedly the Trimble was one of the fastest bikes ever tested. More surface area is good right? And with the frame drafting off of the front wheel, thats gotta be gold too. If it came out good enough, judges might think it actually was a Trimble. “Its not a fairing”, Id say, “I just need a really stiff frame.”
Filling the open spaces of the double diamond with foam, and then wrapping the fiberglass/carbon around all of it.
It probably wouldnt be pretty. But it might be cool?
since the bike is already strong enough to ride as it is, I would focus on making the carbon wrap much lighter, the foam core would be un-needed from a structural point of view (other than helping quieten the rig down) My old giant MCR is hollow and that used to echo every little bit of road noise like mad.
looks like a cool project though, I will be watching with interest, You’d probably get on well with a guy here in kiwi land called Graeme Pearson, he loves doing weird and interesting things with CF and bikes.
I was under the impression, this bike was fastest in side wides cause it acted like a sail, like a disc wheel.
If you look at the drag on a disc vs a deep rim like a Zipp 404, the disc is pretty close to the Deep at 0 yaw, but as the yaw increases, the disc gets faster.
I reject the theory that because something has never been made or hasnt been made recently then its not a good idea. One reason it probably hasnt been made, is that its not UCI legal. And a manufacturer wouldnt make a super aero frame and spend all the $$ on R&D if the worlds best pros couldnt ride it at the Tour or World Champs.
The reason I thought id use foam, was just so laying up up the fiberglass would be much easier, fill in the spaces with foam exactly how I want it to be, then just lay the wet fiberglass over all of it.
Nope!
I assume a disc is faster because it has more surface area. That at higher yaw angles that surface acts like a sail and pushes the bike forward in effect. I would think that a Trimble bike would have the same effect.
A sail works to create lift (thrust) because it is a streamlined body with curvature that is aligned with the incoming flow (wind). The body of a trimble-like bike just acts like a flat plate with increasing yaw angles, leaving behind massive regions of separated flow, with the associated pressure drag. Also because of it’s large surface area, skin friction drag is important.
bunnyman would approve. The bike will be heavy (not as heavy as one would think), and will be a bear in a cross-wind, but it would be a cool bike.
The internal routing would be very easy on this, as there would be no funky bends.
My suggestion would be to make it easy to remove panels so that you could easily service the bladder. I would use some rivnuts on the tubes so that you could attach the panels that fill in the front trianlge. Everything else would be simple, and the weight wouldn’t be nearly as much of a concern because carbon would not need to be structural. I would do like Hed Jet fairings, as they would add a bit more than a heavily filled paint job.
