Theory: Weight training improves recovery
  1. High volume endurance training reduces testosterone levels
  2. Testosterone is good for muscle recovery (just ask Floyd)
  3. Moderate weight training increases testosterone levels
  4. Ergo: Moderate weight training can aid muscle recovery from high volume endurance training
Thoughts?
Sindre, cognito ergo sum
but your muscles have to recover from weight training, too.
two cents
That is a good point, but moderate weight training is not as demanding as for instance a long run.
This fall I am in single sport training, focusing on a marathon in January. I run 6 days a week with 4 “quality” days and 2 “recovery” days. On the recovery days I run 3-5 miles and weight train 20-30 minutes. The weight training is 75% upper body and core because my legs are shot from all the running.
So, does the upper body and core workout benefit recovery in my tired legs???
Sindre
I posed a very similar question along the same testosterone lines to a Physician/ tri coach friend of mine and asked him to rate it from 1 to 14 for truth.
He gave it a three. :slight_smile:
Anecdotally I find it helps, I came across the idea in the Book High Intensity Training, the idea that strength training after a big day can speed recovery. Haven’t seen anything to support it science wise.
  1. Ergo: Moderate weight training can aid muscle recovery from high volume endurance training
There are all sorts of apparently logical deductions and connections we can make with respect to matters of physiology. However, it’s a non-linear complex dynamic system and things don’t always work out like they “ought to.”
The only real way to find out is to try it. A visit to your local college campus and a few hours poking through exercise phys articles and journals will show that it just ain’t so.
3/14 is about as likely a die 1 roll :wink: Maybe not very likely but I’ll keep at it just in case.
Ashburn,
Do you think the naturally elevated serum testosterone levels from weight training are too low to have an effect on recovery? Browsing through a couple of hits on Google I found that the serum testosterone levels were only elevated for a few minutes after a given exercise set. Is that not enough to make a difference?
One study I browsed found that testosterone levels were equally elevated at at a set of 60% 1RM (1 rep max) as a set of 90% 1RM. Intuitively the 60% 1RM set will have a higher potential for benefitting recovery in “endurance trained muscles” while not causing excessive fatigue in the “weight trained muscles”.
Sindre
P.s.: I’d greatly appreciate if anyone have references to studies that have looked at the indirect effect of weight training on muscle recovery.
That sort of detail is way over my pay grade. I have no idea about the details. I was just referring to the end result: Does resistance training, when added to an otherwise adequate program of specific-sport endurance training, improve the performance of endurance athletes? The answer is a pretty convincing, “no.”
Whether such training helps with recovery – I don’t know. But, even if it did, the lack of an end-result benefit would cause me to not do resistance training for that specific purpose. There are lots of reasons to train with weights, but going faster in races doesn’t seem to be one of them.
The question here is not if bench press will make you a faster marathoner. It probably won’t! If you have what you call “an otherwise adequate” program including sufficient recovery, bicep curls will only impress your GF and not the guy who beat you at the races last year and who will still beat you this year. The question is if you don’t think you have “the perfect program”, can you improve your program by being better rested for your quality workouts without lowering volume or even increase volume?
Sometimes adequate is not enough!
Sindre
Maybe, but if you have a nice looking bod then you’ll get laid more than the skinny guy who KYA…
I’ve thought the same myself. Maybe it is just placebo affect, but I seem to bounce back better with moderate weight training. But I think it has something to do with the weight training forcing an alignment of the muscles etc (if done properly). Its just what I feel. It may have no real effect, but the perceived effect is enough to keep me doing it.
As for testosterone levels, is it not just better to get more sleep and release naturally occurring human growth hormone?
Dev
The whole “napping to increase growth hormone levels” makes about as much sense as focussing on the small, transient changes in testosterone that occur following resistance training…IOW, none.
I do moderate weight training for my bones. (am 53) Have found I have very strong training days after my weight days. Don’t know why, may be a placebo, may be just me, but I can train harder when doing weights as well.
Ric
Right! Sometimes we just need to run more. :wink:
