Hey Twitchers…
Ok, I’m going to state off the top, the pictures you’ve seen posted here are of my bike at the Muskoka Long Course Tri in June 2009. I know Tom and I’ve been racing with him and against him for quite a few years. For the record, I’ve been riding with a Wedgie all season. No, IronTom isn’t paying me, I just like the idea and thought that it made complete sense when I first heard about it and after using it all season I can state that it just works.
Questions:
Bottle: Yup, the big bottles work, with lots of extra room. I’ve tried a couple of different types and all of them worked. The shorter ones slide around a little bit (but not that much), but the longer ones are just fine. I personally like the Camelback Podium bottle. The valve on the lid doesn’t allow fluid to leak out when in the vertical position.
Bottle cage: It’s integrated. You can’t buy another cage and bolt it onto the top. It also grips the bottles very well with lots of surface to lock the bottle in.
Ejection: Nope, I’ve never lost a bottle out of the Wedgie. I’ve lost them out the back of my HydroTail until I changed the cages. I’ve lost them out of the custom “between the aerobars” hack job I’ve been using as well. I’ve ridden with the Wedgie on some of the roughest roads in the area (Burlington Ontario) and in Muskoka trying to bounce it out. Nope. Solid like a rock. It can’t get ejected or slide out. You’ll eject yourself out of the seat before you’ll eject a bottle.
Cost: Well, yeah, if you just look at it on it’s own, it’s expensive. However, what’s the cost of a carbon fibre bottle cage ($50-70 CA) and what’s the cost of a bike bag ($20-30 CA). I can see your point here. Now, how much did you spend on the bike, your fancy carbon fibre base and aero bars ($400-$1000), aero helmet ($130-$200 CA), not to mention the wheels to get aero advantage? With the wedgie, on a well supported course, you can remove everything behind your seat and elimate that huge aerodynamic drag. It’s pretty cost effective if you ask me for the significant (abet untested at this point) aerodynamic advantage.
Rubbing: Nope. I have never touched the bottle with my legs and I routinely rub my top tube with my knees while pedaling.
Width: The body where the repair kit goes is as wide as your tubes are. The bottle grips are as wide as a standard bike bottle is.
Transition Times: I can’t speak for the faster out of transition statement, my bike won’t mount on the back of the seat, it just slides off.
How confident am I in the Wedgie?: Well, I used the Wedgie on my third IM race, Ironman Canada, this year. Yeah, my bike sucked, but that was because I had an issue with my brakes on the last half. The Wedgie did what it was supposed to with no problems.
Would I use it in the future?: Damn right I will. The only way I’m getting rid of it is to replace it with a newer version.
IMC 2009 Cool Stuff: I showed the Wedgie off to the Cervello guys demoing the P4 at the expo, and to a man, they were all over it. Their comments were that it was unique, functional and a great idea. One of them said that the Wedgie had “Wow factor”. They even took lots of photos to fire back to head office. They’ve seen it all and they were very impressed with it. 'Nuff said!
Yeah, there aren’t a lot of these out there yet, but in two years, you’ll be seeing them every where… Like Cervello’s at Canadian triathlons. Trust me on this one. It just makes sense.
Mark Collis, proud Wedgie owner and tester
www.ontherun.ca
