add them as you like, but thought we could compile a big thread of " running in cold weather tips" from any viewpoint…be it motivational, what to wear, pace, heart rate, whatever.
please add your tips, the idea is to have a “value-add” thread from which we can all contribute and learn from.
for people with longer hair that tends to freeze from cold temperatures and sweat, consider stuffing your hair up under your hat. This keeps your hair out of the cold, and ice will not form on your hair–it worked for me this past weekend in 9 degree weather!
remember sunscreen even in the cold. put it on long before you go out, allowing it time to soak into your skin. UV/UVA rays are still present and it’s just as easy to get burned in the winter as it is in the summer! for wind protection vaseline can be a life saver.
1 - Nylon shell
2 - mittens or socks on the hands. No gloves.
3 - cover everything (face, ears, hands, etc.)
4 - Consider doing a 5 minute warmup on treadmill or trainer before going out.
5 - Microwave your hat and gloves
It depends on how cold it is. When it’s real cold, say in the single digits or below, I will typically use the same base layer as when I ski. Wicking, thermal long underwear, and thin, wicking ski socks. Over this I’ll wear a medium weight running pant, and a zip up wicking mock turtleneck. Then I add a windbreaker jacket, and some wicking running gloves. On my head I wear a knit cap and if it’s really windy I’ll wear a polypro balaclava under it. Regular running shoes if the terrain is clear, old runners with screws in them for icy conditions, or waterproof shoes for wet/sloppy conditions.
Ideally running into the wind on an out/back course would be the way to start and then have the wind at your back on the return. This is not always possible, so the layering of clothes will help keep you warm. I have finished runs with icicles hanging off my elbows from sweat and ice crusted on the balaclava, but inside I’m actually decently warm.
It is imperative to get inside a warm place as soon as possible after the run because once you stop generating heat from running, the wetness will make you cold fairly rapidly. If you are running in a place you drove to, carry extra dry clothes in your vehicle so you can get out of your wet clothes while your vehicle warms up.
Fill your water bottle with warm / semi-hot water. Or take hot choclolate if you fancy. It will cool down, but it won’t freeze for an hour (unless it’s insanely cold, like -10 F).
Always take a gel or some sort of calories, you can burn a lot of energy even in 45 minutes out in the cold, much easier to bonk, and the stakes are higher.
If your seriously considering bagging it or running inside, just suit up and head out from your home and tell yourself you’ll go for 10 minutes and see how it feels. If it’s really that bad after 10 minutes you can always just turn around and go home but more than likely you’ll feel ok and want to keep going and get a decent run in.
After several times of almost breaking a tooth on a semi-frozen powerbar, I now put a water bottle filled with warm water in my insulated lunch container. Nice and soft and ready to eat after running.
Please remember to hydrate - for some reason, it’s easy to not feel the thirst as much in the cold, but evaporation through exhalation is massive (in light of the low ambient humidity) and modern technical clothes make sweat loss a breeze). I plan my long run course to pass a number of gyms where I can duck in and use the water fountains (and, as warranted, other facilities) - my fuel belt become useless after a while and tends to freeze!
In very cold temps, I use the same mittens-over-liner-gloves that I use in snowboarding. Also, I will make sure to be generous with body glide (over chafing spots) and lip balm - the cold wind in the face freezes and dries out the lips. Double socks and double underwear protect important appendages.
The other critical thing about cold weather running is to watch your footing and look out for patches of black ice. I’ve had a couple of nasty groin pulls from hitting a patch on a downhill and finding myself doing an unplanned split (I tend to begin my long runs very early, long before sunrise, so this isn’t too surprising).
Those tear-open single-use hand warmers really work well.
wear a thin polypro balaclava in really cold weather but Don’t try and breathe through it as it will freeze up and cut off your air supply.
Keep a spare pair of gloves in your underwear. trade them if your hands get cold. I do this climbing in the winter.
My new favorite top is a Gore N2S vest from Mountain Hardwear. Windblocker front, zip jersey pockets in back, and a nice high collar. Since Xmas, I’ve worn it running, biking and XC skiing.
Dermatone is a Vaseline like sun block I use skiing and climbing and it works really well. It also protects your skin from getting chapped in really cold weather. The package claims it delays the onset of frostbite but I prefer not to test that out.
Keep your Gu or other bars down in your undies or an inside pocket. It will keep it warmer and easier to eat if you don’t think about where it’s been.
Kitty Kat, I LOVE your term “value-added”. It reminds me of something my newly minted Harvard Business School graduate sister said to me recently about being a “brand evangelist for value-added products”.
Sunscreen!! I’m usually so bundled, there is no exposed skin!!
I say keep your neck covered. That always works to keep me (relatively) toasty.
