The most successful dopers are reinfusing their own red blood cells,
Ok please explain in few words
Elevated red cell count improves oxygen transport. Pull some blood, centrifuge out some plasma, wait until you’ve recovered and re-inject. Instant VO2max increase.
However, there would still be other tell tale signs of the infusion. Also, the blood will only last so long refrigerated.
this is old technology. lasse viren used it in the 1976 olympics (5 &10km), as did the commie east german cierpinski (sp?) in the marathon. shorter’s attempt to get the pinko DQ’ed and get the gold medal he deserved, went on deaf ears because the IOC didn’t want to acknowledge a 'drug" problem.
Which are?
** the blood will only last so long refrigerated. **
Huh. I wouldn’t have thought this would be an issue. Does this explain why Vino used someone else’s blood?
1- no drug test currently available can pick up this method of cheating… so it’s a cheat of choice by athletes…
2- more sophisticated- b/c your own blood is extracted- so it’s a lengthy process- from your blood being extracted, you then have to produce more red blood cells- (several months) and then the dr. reinfuses your older rbcs- so you are turbo charged…
3- expensive and time consuming
4- super effective at increasing performance- does what epo did- without risk of testing positive for epo
Since blood doping wasn’t explicitly against the rules in 1976, there would have been no basis for disqualifying him (them), even if tests had existed at the time to detect it. It is because of this grey area in the rules that the US cycling team employed blood doping in 1984: they felt that they had no choice but to do so to “keep up with the Joneses”.
It is because of this type of “doping” that riders who race infrequently, yet give huge performances, are suspected as doping. Time is needed to extract blood and recover, so this is not possible for the typical pro who races one average several days a week during the season. These people are even more suspect when their results prior to racing infrequently don’t justify their success. I suspect this is the basis for the LeMond comments regarding Contador that are now being debated in another thread.
Paul
Other Hormone, Protein and K+ levels would be bumped. I forget alot but this I do know. The average RBC lasts for little over a month stored. However, that is about the time it takes for your body to replenish them also. So when it comes to analogous transfusion it is a mute point for a cyclist to do his own for performance stand point. In addition, you really raise the bar on pathogens being introduced into the blood stream. With these guys immune system constantly being in a battle due to hard training, it is not a smart risk.
I feel like you are trying to imagine a way in which a world exists where riders are not doing this.
this of course ignores things like, operation Puerto where all the top contenders got caught doing just this…
I am going to stab myself in the eye
I am not sure if I’m misunderstanding you, but that doesn’t seem to make much sense. Specifically:
** The average RBC lasts for little over a month stored. However, that is about the time it takes for your body to replenish them also. So when it comes to analogous transfusion it is a mute point for a cyclist to do his own for performance stand point.**
That wouldn’t make it a moot point at all. You take out a pint of blood, wait a month while the body replenishes it, then put the original pint back in. Oila! An extra pint of blood that the athlete would not have had otherwise.
This doesn’t make sense to me, either. Using your own blood, instead of someone else’s, surely presents a much lower risk of infection.
Lest not we forget that Olympic Cycling Gold Medalist (1984) Alexi Grewal was also purported to have done the same.
What are the health risks associated with this process?
ARC sets a shelf life of RBCs that have been processed at 42 days. It is possible to keep them longer if you really want to. You can recover your losses quicker if you use EPO to get it back up. Which is why everyone is so worked up about guys going underground to avoid out of comp tests. The EPO test is only useful for a couple days after the EPO does is taken.
Main side effect are issues with blood cloting and viscosity.
There are research projects underway to look for experssion levels in genes an indirect marker, and then things like membrane structures, antigen expression and other blood stats are direct markers. Nothing solid has been developed yet.
I dont think that’s right Andy. Why did we have to pee in the bottle in the 76 and 80 OT? The IOC had passed some type of anti doping rules after a penis slipped out of that East German Female Shotputter’s shorts by accident in 1972.
I don’t think that AC said dopinbg wasn’t illegal, just that blood doping wasn’t. No “pee in a cup test” can detect blood doping.
Styrrell
