Years ago I was at a party with a colleage (both mechancial engineers). The wives were gossiping about something and the boys were drinking and telling lies about how great they used to be. Somehow, my colleague was trying to impress one of the non-engineer with his impressive knowledge. I quite respected my colleague at the time, but he said something I disagreed with and we got into quite an involved engineering discussion.
We ended up in his home office, pulled out a psychrometric chart (illustrates the various properties of air) and started pointing and waving our hands about. The other guys in the discussion went quiet while we discussed and worked through the problem, calculators working furiously. Eventually I convinced him he was wrong and I was right and the others were well impressed that either of us could read, let alone understand the psychrometric chart.
We were discussing differential enthalpy of air within an attic in summer, versus the air in the ducts in the attic I talked my colleague into understanding that he’d been wrongly designing A/C systems for years! He changed his designs from then on…well, until he left the company and reverted to his old ways. Interestingly, I had a client come to me saying the ex-colleague had designed an A/C system but it was using tons of energy to keep the place cool. I reviewed the design, found he’d done it his old way! I explained what the client should do, they did it and their energy use dropped considerably.
Engineering is fun. I don’t remember rotational inertia formulae off the top of my head, like Damon does, but I still like calculating things. Numbers ROCK! I also remember that my father (NOT an engineer) used to say “Every bit counts, says the old man as he pissed in the sea”
And no boobies were touched that night.
That is SUCH a stereotype. However, I can’t argue the point, because it’s right as a rule, right in the case of that night.
I will point out though, that I was a pro skier for a number of years before I became an engineer. I have touched more boobies than just about anyone short of rock stars or porn stars. That might explain why I’m only a mediocre engineer!
Here’s some answers to the questions floating around (I’m the guy who designed CrankPump)
By the way, CrankPump is in its last few days on Kickstarter, and there’s now a free “economy” international shipping option.
It looks like tools are not needed to remove and replace the device from your crank. That means it has to be reasonably loose, which in my experience means it will slowly work itself free, which would be annoying. If you need a tool to remove it or tighten it, that kind of defeats the purpose as you’ll have to carry that with you.
Crankpump’s shape is carefully designed so that you can un-tighten it with more torque than you can tighten it, so you can tighten it as hard as you like and it will never be stuck. When you tighten CrankPump, you use the rounded outside shoulder (as in the image below) when you loosen CrankPump, your fingers can use the flat ends of the indent on the front. The flat ends of the indents allow you to apply more force, but the flat ends can only be used in the anti-clockwise direction, so high-torque can only be applied for undoing CrankPump. This works like the opposite of a security screw. It’s never come undone so far in testing.
I’ve never flatted and had the problem be solved by simply pumping up the tire again. You will in 95% of cases, barring a very slow leak needing just enough air to get home, need a patch or inner tube. You can just tape a patch kit to the underside of your saddle, but I think most of us carry spare tubes. If you’re carrying a spare tube in your pocket or saddle bag, it’s trivial to also carry a co2 canister (and I always carry multiple co2 canisters).
Nice that you point this out - a glue-less patch fits pretty well into the axle along with CrankPump! I suspect that most people are still going to want to carry a spare tube stuffed under their saddle.
Does that make CrankPump useless? no, CrankPump is one less thing to carry in your saddle bag or pocket. That’s less hassle and slightly more aero. Slightly better is worth having: nobody complains when Shimano makes slightly better cranks every year, and it’s the reason you paid more for hollow axle cranks in the first place.
Those tire levers are not going to work on a number of wheels where the tire is tight. I’ve had wheels, like the aluminum brake track Zipps, where they broke normal tire levers just trying to get the tire removed. There is no way you’re getting these “patent pending” tire levers under a tight tire. Also, I’ve always “unzipped” the tire from the wheel with normal tire levers once they’re under. They’re acting like this is something new.
TyreZips are different from the levers you’ve used before. They begin by “hooking” the bead off the rim with a wedge action, not a lever action like normal levers (see steps 1 and 2 on the image below)
The bottom of the TyreZip is smooth and rounded, so it smooths and guides the bead over the rim. This acts as a wedge (the distance travelled in the fore-aft direction is much greater than the distance travelled upwards and over the rim). A wedge is a different way to apply force than the lever method used by traditional tyre levers, that’s why it’s patent pending. The third step of unzipping the tyre is what you’ve done before with a normal tyre lever, but better because TyreZips have profiled edges to make it easy.
I think they’re trying to solve a problem that doesn’t exist. Do mini bike pumps really “beat up your kidneys”? In any case, compare apples to apples and compare this to putting a co2 canister and one of those mini inflators in your pocket. I hardly notice they’re there once they are in my pocket, and I have a little bag with a patch kit, tire boot, 2x co2 canisters + inflator, multitool, and spare tube that I grab every time and stays put unnoticeably in my pocket.
Do you have to remember to take your mini pump? Does it take up space in your saddle bag? does your pump make your bike look uglier?
do you sometimes decide not to take a pump or saddle bag on short trips? Those are problems crankPump addresses. It’s nice that you’re used to carrying a bag around with you, but it would be better if you didn’t have to.
That said, I would buy one of these once they’re successful and out in the real marketplace (not the “donate and pray you will get something in 3-6 months” Kickstarter marketplace) because I could always use a spare co2 canister, especially on those super cold days where your fingers aren’t working right. Also, it seems pretty innovative to store something in the center of the crank and I would like to support that.
Thanks for the vote of confidence! Also for the thoughtful comments. The tricky thing is that unless CrankPump is successfully Kickstarted, it probably won’t make it to the real marketplace. CrankPump has 4 more days to run, and needs to double its current funding. That’s going to be a bigger challenge than any faced so far.
