Im nervous about the run leg. IM OZ will be my first.
I did a 180km ride last weekend and managed ok, but i have had a running injury. So i took 2 weeks off.
Now with 10 weeks to go, i need to get my run back on track. I am currently running 2x week and my long run is up to 1hr. I am cautious about increasing my run volume too much and getting injured.
What should i do to maximise my lead up. Run 4x per week? what about 2 runs per day- say 1:10 each. is that cheating
or is it better to do something like a triple brick, 3x (bike 1hr/run 30)
and … how much running do i really need to get in beforehand. (PS- i think you guys who log 3hr runs are nuts!)
any thougts, advice, quick fix!
Personally, I’d run 5 x week with the long run most important for an IM (no need for tempo or speed work), but the long run after a long bike on tired legs would be best. Some hill work will help with some quad strength, but be careful with your injury (whatever it was)
I think you’re going to do fine. No 3 hr runs----do 2.5 hours max. Also I wouldn’t do your long run after your long bike, that’s asking for trouble. Do your long run on fresh legs. Do a transition run (20-30 min) after your long bikes.
lots of stretching, ice what hurts, ice baths after long runs. How tight are your hamstings?
I have read that you should avoid long run after long bike. It makes sense to me, but everyone tells me- you gotta train to run with tired legs, and i say , you cant train tired legs!!
i was thinking my max brick would be 5:30hr ride and 1hr run off the bike. is that too long?
I have read that you should avoid long run after long bike. It makes sense to me, but everyone tells me- you gotta train to run with tired legs, and i say , you cant train tired legs!! i was thinking my max brick would be 5:30hr ride and 1hr run off the bike. is that too long?
You can’t race on tired legs either. Remember, you aren’t training for a 15K race that only takes 1 hour. You can “train” tired legs (but be careful as your chance of injury does go up). But, maybe, you aren’t planning on “racing” the IM either (and that is perfectly OK). If you are just trying to finish, then I would find it even more important to “get used” to the feeling of the brick legs, since quality/speed will not be so important. There is just not enough time in most peoples days/weeks for “quality” long runs, long bikes, multiple open water swims, etc. Pros have this kind of time - I sure don’t.
edit: I just realized that you might be thinking about a 5-6 hour bike ride, THEN a 2-3 hour run. NO. I mean the long the run the next day. That is “tired” enough. An easy 45min to 1 hour brick is OK off your long bike though. Racing strategy, etc. would put your long run on Wed night though, then the long bike Sat and/or Sun, but that is not always possible.
No. Just run long - remove the pace and remove the hills if you have to, but don’t remove the time. You should be able to do 2 hours pretty easily by now. Run within the injury’s pain window and you should be OK. Otherwise you won’t do an IM run, you will be doing a 5 or 6 hour IM “wander” consisting of run/walk/stop/stretch/rest/pray/toilet…
Focus on not aggravating your injury. Take the extra time and boost your swim/bike fitness. Run what you can.
Quick fix = change your race plan. Bike 15 min slower (10 in the first half and 5 in the 2nd) to leave yourself fresher on the run. Start the run slow - start walk breaks at the stations at mile 1. You might be surprised how well you can run in an IM with minimal run fitness…esp. if you are realistic on the bike and the first 15-20 miles of the run.
I am currently running 2x week and my long run is up to 1hr. quick fix!
you should be nervous since that is pretty low volume for 10 weeks out…but everyone is always nervous about an im, so join the club…there is no quick fix and from where you are, you just have to figure out how to do more running…i would say that from here you should target 4 hrs/week for ~6 weeks before the event plus two weeks off/‘drop dead’ taper…so you need to get to that volume in 2 weeks from now…again, no quick fix nor magic work out, just get the hours anyway you can, anything ‘counts’, including multiple runs per day to make the hrs…i like the idea of 2 x 1 hr runs (wed & friday) and 1 2hr (sunday) with long bike on sat…
You will be fine, just prevent the injury from flaring up again. You can try some water running (check with physio first) and just do easy short stuff 1 hour max.
I have an ITB flare up 4 weeks out from IM OZ last year and had to have a jab, the doctor wanted me off my leg for 8/10 days. The last day befor I was due to do a 12 km test run to see how the jab went I did an open water swim and getting out (in a dam) stood/kicked a nail that went 25 mm strait into my foot lengthways, inbetween my big and second toe. A tetnis shot and some dressing and I could not put my foot on the ground, let alone run. I was only able to walk normally on it 3 days before the race.
I am a moper and still got home in under 11 hours…just.
note just re-adjust your goal finishing time, its IM its all about finishing the time just gives you something to better next year or the year after, they all say they want to do just one. Its like a drug you just keep coming back.
Look forward to it you will have a ball, but don’t re-injury it now or it might be a long day out.
