Don’t know if this one exists (doubt it), but if I could build one up, it would look lilke this:
12 14 16 17 18 19 20 22 25
Basically, I find the 12 and 13 redundant. Any condition where I can actually push a 13, I can just as easily push the 12 (ie downhill…). The 11 is way too small a cog and really if I can use this cog in a triathlon, I am better off saving my legs and coasting (ie I am already rolling along faster than 60 kph). Where I want “tight spacing is 16-17-18-19-20”. These are my flat and rolling terrain gears. Tight spacing here is great. Once I get beyond 20, I am hitting some steeper hills, so I am quickly needing to shift from 22 to 25.
By the way, I run a 48 tooth big ring. I spend all my time on the flat and rollers in the big ring. When I get into some serious hills, it is over to the 34. In that cog, the 34x(16,17,18,19,20) is really nice for a long sustained climb, saving the 22 and 25 for bailout when it gets super steep.
I really don’t understand the utility of many cogs that start with 11-12-13-14…basically a waste of gearing.
What studly gearing are you 55 tooth guys using…is it something like 11-12-13-14-15-16-17-18-19 ?
DP, you might be able to bastard build close to that cassette out of a couple of SRAM PG-970s …all their cogs are seperate and come apart with a 2mm allen wrench. They have 26 vice 25, though.
I normally run a 11-23 DA with my 50/34 compacts for the rolling Quantico, VA terrain…but when I’m headed to longer climbs to the west of me I’ll slap on the 12-26 SRAM cassette…the 26 does, indeed make a good bailout gear when needed…
Brian, that sounds like a good plan. Remember the old Regin a freewheels when you could do just that. When Shimano first started using the freehub bodies we were supposed to be able to build custom, but that has gone out the window !
If you are in Quantico…is Doug Marocco still there. If so, say hi. We met at the World Military Games 1995 and then again at Wildflower 96. At the 95 World Militay Games the top 4 looked like this:
Hellriegel
Dmitri Gaag
Norman Stadler
Olivier Marceau
and way back in finishing the race two time zones off the pace
We apparently ride very differently up here in the Northeast where the hills are severely steep but not many are more than a 1/2 mile long. Not much in the way of flat riding here at all. Certainly nothing more than a few minutes long. I don’t know even a single person who rides a big ring of 48, nor even one person on compact cranks.
I’ve always ridden on a 53/42 up front (650 wheels) except for experimeting with larger rings a few years ago. My rear is an 11-23, which I’ve modified a bit. This IS my ideal cassette. I believe it is a 11-12-13-14-15-17-19-21-23. I ride in the 42 down to the 13 where the chain angle gets too steep to go further and then use the big ring for only the 11-12 cogs. I’ve been considering experiment with a 39 up front because I’m simply not as strong as I was 10 years ago but worry that it’ll throw everything into confusion.
Where are in you in the Northeast ? I used the 48 with a 12-23 at Tupper Lake Half Ironman for a top 10 bike split. Seriously, unless your engine is within 10% of Lance, why would you use gearing (transmission) that is geared within 10% of him. Really, you need to be substantially undergeared compared to a pro rider. Most bike shops and manufacturers sell us pro gearing, when when our engines are not even within 50% of the top pros (top marathoners run 2:0x, competitive age groupers around 3:00. Lance and Pantani did Alpe D’Heuz in sub 40 while competitive amateurs barely go under an hour).
I was riding with a young lady a few months ago who thought she was a “grinder on hills”. The only reason she was a grinder on hills, was because she ran out of usable gears at the low end and even when she was not out of gears, her cadence band was pretty limited, so she would benefit from tighter gearing in the middle to stay in her optimal cadence band.
I’ve been doing the Mt. Diablo hill climb in northern
cal the last few years and am trying something new
this time. I used a compact crank with a 12-25 last year but
could have used more middle gears at the start, which
is only ~5%. I noticed shimano is selling an ultegra
level 14-25 for juniors giving 14,15,16,17,18,19,21,23,25.
A great climbing cassette, as long as you don’t mind
coasting downhill.
Hey man, not telling you what to do. Perhaps you have the engine of a pro biker and need to use the same gearing. For the rest of us, we need gearing for our lame engines :-). Don’t knock the 48 tooth ring until you try it though. It really gives you lots of usable big ring gearing :-).
Back to the original topic, can you get such a set up with a Shimano cassette ?
You could use this same junior gearing and replace the bottom two (which are the ones that come separate) with a 12 and 14. Then you get 12,14,16,17,18,19,21,23,25. This would be excellent.
Where are in you in the Northeast ? I used the 48 with a 12-23 **at Tupper Lake Half Ironman for a top 10 bike split. **Seriously, unless your engine is within 10% of Lance, why would you use gearing (transmission) that is geared within 10% of him. Really, you need to be substantially undergeared
Ooooh…gang up on Dev time. Dev was that top 10 before or after your 4 minute drafting penalty? LOL …
I agree with you, but a 54 or 55 would look so much nicer on your new P3.
OK, top 10 in Peterborough…no drafting penalty :-). .Trev, bring your mangears out to the Ottawa half Ironman :-). I got my P3 so we’ll be even
No can do on Ottawa! Seasons over. I’m already riding my fixie (39X16 BTW)!
I think your right that 48x36 and 12-25 is ideal for most athletes (and probably 48x34 and 12-27 for many).
As I’m already sunk into a 53x39 DA crank, I run a 13-25 junior cassette in the back. (Honestly, who consistently needs a 53x12 in a triathlon? Nobody I’m pedaling near).
I don’t think they make a 22. Otherwise you’d be good to go. Are you on a 42 or 39 up front? If you’re running a 42, try going to a 39 and running this in back:
13-14-15-16-17-18-19-21-23
That’s a custom set-up as well. I used to take 12-25 8-speed cassettes apart a, pitch the 25 and put on an 11-tooth, so then I’d have:
11-12-13-15-17-19-21-23
And for racing I’d go to an 11-21 the same way. SO I have a rather large stock of 23 and 25 cogs. What, you say you can’t run the cassette without the screws holding the whole thing together? Guess then I really HAVEN’T put in all those miles over the years, and I just imagined it… Just run that lockring on tight, and it’s no problem (do NOT do this on aluminum freehubs).
I’ll second this observation. I took apart an old 12-23 8-speed, unscrewed the pins, took the 23 and changed it out with the 16 on a newer cassette. I can’t remember if I bothered with the pins or not. I rode the new cassette for a long time.
Last spring I decided I really missed the 16-tooth and wanted a 25 so I bought a 10-speed cassette and put it on to see if it would work. The only thing I lost in the bargain was indexing on my shifters, but I forgot all about that inside of 10 minutes.
A 10-speed 12-25 is a really great cassette. You don’t need a new derailleur or new shifters, and perhaps not even a new chain. I used to think having ten gears in back was silly; now I think it was a great, no-compromise idea. It gives you a good range from 12-17 in the big ring and 14-25 for the small ring without a really bad chainline (though the 25 is a bit of a stretch on a crank with a wide Q-factor).
