How is it possible that Floyd increase his testosterne level so hi, so quick, how is it use? and what is the effect?
I’m not so sure about testosterone, but I read a very interesting study on very high and acute doses of estrogen in men that resulted in significantly higher fat burning capacity and significantly better endurance times. Maybe something similar is happening here with T? I think there is still ALOT to learn about the acute effects of high doses of various hormones.
That is what awakened mycuriosity , i have heard good thing about a dr. prescribed doses of test… so i think that a lot of my age groupers and the road racers that i go against are using something, i have seen a big increase in their level.
There are some pretty big negatives in trying to raise testosterone through external supplementation, though. From http://www.hammernutrition.com/downloads/JOE/mar05.pdf
“Since anabolic testosterone levels decrease as a result of exercise to fatigue training, and
catabolic hormones increase at a greater rate, why raise or not raise the anabolic
testosterone levels to enhance recovery? A negative feedback loop results in response to
elevation in testosterone, which further depresses testosterone and its anabolic donor
properties for anabolic muscle growth. When this happens, testosterone is depressed
longer than elevation in the beneficial hormone increases initially released.”
You can find the data/results through his blog, but his T/E ratio was high. His testesterone was normal and his epitestosterone was depressed, leading to the high ratio.
There are more and more people that are trying to push for testosterone suplementation to combat aging and symptoms of aging. I guess that its not too different from HRT for women going through menopause. (some actually call it male menopause)
In one of his `health for cyclists’ books Andy Pruitt recommends a combination of DHEA and Diindolylmethane for older men, and while this may both raise the level of testosterone production and change estrogen metabolism to also increase the level of unbound test, I don’t think these will increase DHEA/test levels beyond what they were when you were younger.
I’m no endocrinologist, so don’t take my word on any of this.
That would be a huge gain though, to get back to normal levels. Same idea as not losing water or hydration loss leads to loss of endurance. same idea.
I think Floyd could have been using a synthetic hormone. He used it many days prior to test. It doesn’t have a instant effect. But if he used it before some could have been stored in his fat cells. Which he used up the day before and the testerone got into his blood stream Could be why is ratio was so far off.
