Who did you think I was? I wasn’t attacking. CDW was looking for an answer to a question and Paulo gave him a Paulo answer. Earlier today the same thing happened and someone called Paulo on it, without resorting to name calling, being somewhat blunt about it, but relatively polite. I pasted what that person said and prefaced it with “not really trying to insult or anything.”
As I said, if the price for Paulo’s information is dealing with his personality, it’s worth it. That said, Slowman has never threatened to kick me off the forum…Paulo can’t say the same thing.
Why you called me an “arrogant prick” when, as far as I know, I don’t even know you, is beyond me. So again I’ll ask, do I know you? Have I crossed you in some other way?
dude, wait a sec…my last post was not attack. i was saying you were not the type of person i had refered to you as in my previous post. you post right before mine showed that you really do understand what paulo was trying to say. i thought you were just one of those guys who was jumping on the bandwagon trying to claim he doesn’t add any value to the forum when he really does. yes i was a jerk about it. im totally over it if you are too, and i was serious about riding together some time. i live in arlington and do a fair amount of training down at hains point. you ever down there?
back to the OP, you are completely crazy if you are going to try to quantify the differences between the P2C and the P2 in a field test…
Sorry to have hijacked your thread. Hopefully a little bit of info will make up for it
Cervelo is pretty secretive about their wind tunnel data, but if you do a search, Gerard has said several times, that the P2C tested slightly better than the P3SL in the tunnel. And I believe the P3SL was sort of the gold standard for aerodynamics in terms of aluminum frames, more aero than the old P2 I would say. SO therefore, I would wager that a P2C would certainly do a little better than you old P2. How much, I don’t know, but if it was better than the P3SL, I would guess it would be even a little “more better” than an old P2.
Im not sure how accurate this is, but somebody I know whom owns both a p2 and a p2c was telling me how the p2 is more aero than the p2c…
I’m sure…and it’s not accurate in the least
Yeah, I know cervelo is good with their info, Im just saying that the difference between the two bikes (other than frame material) is probably the tube shape, making the p2(sl/alu/whatever) more slippery than a p2c.
I think you might have that backwards.
I’ve managed to get my hands on both an old P2 (of which I am a former owner–thanks HH) and a new P2C that a friend’s wife let me borrow because she is having back problems. Would anyone care to hazard a guess what kind of difference I ought to see in a 20K trial with the same average wattage? I’m also comparing it to my other tri frame (Yaqui) that has an aero down tube (26 mm width) but normal other tubes and a Ouzo Pro (not aero fork) with regular round base bar. The other two have VT bars a la Cancellara.
On four of my previous five runs on the Yaqui I have recorded times within 28 seconds of each other, so I’m hoping another six or seven will give me a good starting point for comparison.
Chad
The “problems” with a P2, as I see it, are at least twofold: First, as Gerard has discussed in past, the seat tube on a P2 is a LOT wider than either a P2K/SL or a P2C. This will affect the drag. Second, the frame is HEAVY. So, depending on how hilly the course is, the extra weight of the P2 could be a hindrance.
Also, this set of data shared by Dr. Coggan shows a P2 to be ~.15 lbs higher drag than a Hooker Elite.
He also recently revealed that he measured (at the A&M tunnel) the P3C to be slightly lower drag than the Hooker. My guess is that a P2C is most likely the ~same drag as the Hooker, all things being equal.
So…based on that, I’d expect the P2C to be 1 to 1.5 seconds per kilometer faster than the P2. That would be ~20 to 30 seconds over 20K. Again, that’s assuming all other things are equal…and understanding that this is just an “educated guess”. YMMV.
The P2 wasn’t that heavy, maybe 3.5 lbs for the frame (including the seatmast). All in, the last version of the P2 with Smartwall tubing would be about a third of a pound heavier than a P2SL with the aluminium seatpost. The P2 also used 650c wheels in all sizes, which would bring the weight down a little bit as well.
I don’t recall the seat tube being particularly wide. IIRC, it used a 25mm seatpost, so the seat tube would have been about 27mm. But at the same time, the seat tube was a lot deeper than the P2K and P2SL. I believe that Gerard has said that the P2 and P2K/ P2SL were roughly the same aerodynamically.
Hmm…I thought I remember reading it being heavier than that…more like 5 lbs or so for the frame.
If the P2 and the P2K/P2SL are roughly the same (however, I thought I read that the P2K/P2SL was slightly better due to the thinner seat tube…but, I digress…), then I’ll revise the estimate to 0.5-1.5 seconds per kilometer…again, a SWAG
You’re right…I remembered wrong. According to this, it looks like it’s more like 4 lbs for the frame since a P2K frame is a bit more than 3 lbs. (and including the seat post of the P2k as well for an “apples to apples” comparison.)
Thanks,
That gives me something with which to work. I may not be able to come up with anything conclusive in my test given the crazy wind around here, but enough repetitions ought to yield something.
Chad
Over 20 40 km TTs under identical conditions, including wind (Paulo), I was always faster on the 1st bike P2/P2C I rode. The second TT following the first was always slower! Most of the time I rode the P2 first and, consequently, I found the P2 to be consistently faster over a 40 km TT than the P2C.
On the rare occasions I rode the P2C first, it was faster than the P2!
Net result, however, the P2 was faster more often than the P2C!
By the way, you discovered a variability of 28 seconds between your TTs. What was the standard deviation and which TTs were outside the “normal” boundaries? You do need this information to make your quantitative analysis of the two bikes valid.
Actually no. I like to keep things well separated and I would never have a work-related discussion here.
This is the place where I say stuff like “Fuck off troll, get a life and leave me alone!”
Funny comment from a guy who manages to post 10.5 times per day.
