Tell me about Criterium racing
My roadie doesn’t have a power meter, does that matter?
No, you generally don’t have time to look at a PM during a crit anyway. I sent you a response via PM based on the averages you gave me.
Oh, and yes, you can do as many races in a weekend as there are categories that you fit. You will at least be able to get 3, if they have the 4/5 category again.
John
give me your peak 5 second, 1 minute, 5 minute, average power over the last year
and your peak ~45 to 60 minute normalized power
Don’t have a 45 to 60 minute normalize power rating, but my last 40K in a race was NP 182 with AVP 168, that was a 20 MPH average.
Other stats were a 2:21 hour group ride with 30 sec (414 watts), 1 min (363 watts), 5 min (263 watts) with an overall average being 145 watts. But this had some stop lights in it.
Like I said, I’m 210 lean.
Assuming power data is accurate, hang on for dear life!
At your weight with those power numbers, you will most likely be dropped during the race. But keep at it. Your power numbers will probably improve as you race more.
You’re in Austin, right? Know anything about San Antonio crits?
What power should I have where my fitness is fine and I can devote all my mental energy to bike handling/situation awareness?
They are usually a bit easier than the driveway crits here, but you never know. It just takes one jerk to make a race insane.
I wouldn’t worry about power numbers, just go try it out, if it is too hard, you’ll be alone to contemplate life soon enough.
All you need to know… crit racing is FUN… DO IT! “Hold your line”
I laughed harder reading this topic than I have in a while…reminds me that I read ST Forums for entertainment
Yes, Avondale. I’ve been riding with Tribe Scottsdale, One and Tri Scottsdale. One and Tri Scottsdale are of course geared towards triathlon, Tribe is a lot of cyclist and Carlos O’Brien/Tribe Elite racing members.
Being one of the first races on the calendar Avondale pulls decent size fields for AZ. Guys I never see later in the year show up and are a little too amped up imo. So don’t be that guy. The course runs clockwise and is about as easy and safe as it gets (D shape) with wide roads and sweeping turns. Turn 2 is not tricky it’s just that if you are on the outside (in this case to the left side of the field) the pavement just past the turn drops off into the dirt somewhat abruptly. There is no curb on the outside of that section. If you aren’t paying attention and run off the road there is a wide dirt shoulder so guys with little experience freak and over control and go down. I’ve seen a few run off and just chill out keep it straight and bunny hop back up on the road as the field passes.
In addition, this is a good course to stay on the outside as you will use a ton less energy and can move up through the field a bit if you want to. From the last turn to the finish is about 650 meters. It’s a sweeping right hand turn usually with a wind from your left. So, ideally you want to be sprinting from behind up the right side. Problem is everyone else is fighting for that spot as well. Depending on who shows up many field sprint go pretty late and rightfully so. I think it’s possible (if you have some snap) to come from way behind (10 deep maybe) and swing a touch wide towards the left as the road straightens to the line. You’ll be out of the draft but, you’ll get the jump and a clean run at the line. Many times guys will have good position on the inside but get trapped. Some will make crazy moves towards the outside to get free and bump/crash into someone coming up the left side of the line. Between now and then try and get a good idea of how long you can sprint after 30-40 minutes of surging. Usually less than what you think but, I’ve seen many former triathletes go for long ones and pull em off. I guess I’m just trying to say don’t be afraid to give it a go on the outside if the inside looks stupid silly.
I hate doing it, but, if ever there was a race to sit in this would be it. Nothing will get away (cat 5, 4 or 3 usually) so saving energy will be advisable. Masters and the 1/2 often have breaks stick. Even if there is a small break the organization is usually really bad and enough guys will chase for no reason and everything gets pulls back. If you want to try and break try to get a few to come with you. Just don’t sit on the from riding tempo/threshold pulling the field. Just be aware each time you break, bridge or chase you are burning matches and if you are unaware of how many you have you can easily deplete enough energy that you won’t have anything left for the last few laps when it counts.
Carlos and tribe are joining I hear so you’ll have plenty of guys to ride with and have a good time! There are about 500 more crits on the calendar so don’t get bummed if this one doesn’t work out. There is the UC up north every Tuesday night you might want to ride just to get a feel for the kind of pace you’ll see. They have a A and B ride so lots of opportunity to tune it up before the real deal.
yeah i’d start doing some repeat intervals of 120/60/30/15 seconds and just be ready to hold on come race day. maybe see if you can go hit up a short circuit with some guys who race to feel how hard that surging is really going to be.
cat 5 is all over the place. Two year ago when i started out in the 5’s there were 30 min crits i won off less than 210AP and 40 min crits hanging on for dear life close to 300w AP, you just never know who will show up. Not till you get to the 4/3’s do things settle down and the ability level is on a level playing field. In general the 5’s will have more surging through corners so stay in middle-front of the pack, don’t ever pull on the front unless you are in a breakaway and need to contribute to win. I will say it again do not pull or waste energy in the wind, if people are pissing at you that is their problem, do not help anybody else out with a free pull. Hold the wheels as close as possible during turns and anticipate surges in the pack. I also prefer to be on the outside front 1/3 if the group is still together, as it allows me to jump onto the big moves easily.
Also the 5’s tend to chase most breakaways down pretty fast but if it is an well timed attack and you are very strong you can get away. Don’t underestimate those around you. This year we had a guy who won 10 straight 5’s races, then 7 straight 4’s, and then blew all the way to cat 1 in one season…he was a cat 1 MTB and cyclocross and the local official refused to let him skip ahead. Last lap is key and you need to be in good position starting the second to last lap. When i was in the 4/5’s i would be around 260-80NP each lap (150lb rider), but the final two laps were typically around 300 for the second to last and 350-400 for the final lap.
That’s a little bit of a surprise, they had a not so great split about 3 years ago. Wonder how that affects Trailhead being the Carlos shop sponsor.
John
Biggest worry is your asking triathletes about crit racing… :slight_smile:
Joined a team to get some early year races to I don’t go into complete withdrawal. I will be a cat 5 racer (beginner). That is about all I know. The courses appear short, as long as I hang in the group with my aggressive riding skills, I can use my super sprinting ability to pull the breakaway and win.
But that is about all I know, and I’m probably full of shit and don’t know it.
If you’re coming from a triathlon foundation, you will be a threat to you and all of those around you. Might I suggest joining a casual cycling club and learn how to handle a bike and hold a line before attempting any sort of bike racing…
John
Not sure. I’m just a roadie. I’ve watched Procon/carlos and Tribe road teams ebb and flow for a while and a number of things changed when Glen purchased Tribe. Can’t imagine Trailhead and Tribe doing some co-sponsor thing but, I don’t know squat.
Like I said, I’m 210 lean.[/quote)
You will have your ass handed to you, initially. It’s a necessary step for most mortals. It’ll get better once you adapt. Good luck.
Crits are dumb…
/thread
Ok in all seriousness as I am a self proclaimed Crit specialist (not to be confused with breakaway artist or tt specialist) they are awesome.
Go out, stay relaxed, avoid death gripping your handlebars and report back. To try and hypothesize about where to redirect your training would be pointless.
If you want some additional long winded advice pm me your email address.
All of my cat-2 upgrade points have come from crits. Does that make me a crit specialist? :wink:
You’re special that’s for sure…
Short bus special at best…
