I think you’ll be fine. Unless you have the new Dura Ace BB with external bearings then you most likely have the Ocatlink BB; since you said 9 speed I’m pretty sure that’s what you have.
I had Ultegra 9speed with the Octalink and put the same Ritchey cranks on that you are talking about, no problem.
Did you have to use a compact front derailer? I’m thinking all I would need to do is put the cranks on and get my current front derailer adjusted. Did you have to take any links out of your chain?
I put a Ritchey compact crank on my bike. I was able to put the crankset on, lower the front derailleur (ultegra), take a link (or two) out of the chain, and ride.
I posted this on another thread a couple of days ago. I have FSA K-Force CC on two bikes with DA 10 speed, der’s front /rear braze-on. The only problem is I have dropped the chain several times over last season. Both bikes have done it. I had it worked on by several people. Don’t get me wrong it does not happen often, but it does happen. I have a third bike with FSA SLK w/DA but it has a clamp on front der. I have never dropped the chain on that bike?? It might be user error. That said I put Campy Record CC on my new Litespeed.
Maybe I should try this “Did you have to take any links out of your chain?” Or a compact front der.?
I have the Shimano R700 compact crank along with Dura-ace 10 speed double front derailler, but Dura-ace triple 10 speed on the rear. This was the setup advised by Slowman in an article he wrote last year regarding generic compact crank setup.
Reply to: I have the Shimano R700 compact crank along with Dura-ace 10 speed double front derailler, but Dura-ace triple 10 speed on the rear. This was the setup advised by Slowman in an article he wrote last year regarding generic compact crank setup.
That was a good article. I have been running CC since. As for the rear der. “I think” the rear cass was 11/27. I will look for the article so I can read it again.
Thanks for all the helpful replies. My road bike has a clamp on front derailer so that can be adjusted as low as I need. My P3 is on a braze on clamp. Did anyone put a compact on their P3? Any problems there?
I to have the same problem
I will get a cc braze-on front der soon.
"I’m looking at putting compact cranks on my road bike. It’s a dura-ace nine speed right now. I’m thinking of putting these cranks on it. "
9 sp DA on my road bike with Stronglight 50/36 compacts and zero problems, even with Q rings. Shifts just as easy with the 53/39. I had to lower the fr. der slightly. Sorry for the over size photo..
I have installed compacts on my plasma, after a lot of reading, I decided to go with the shimano r700 set.
i had heard a lot of negative things about other CC sets, wheras the shimano set was promised to work fine with the standard FD.
out of curiosity I went for a ride BEFORE adjusting the fd, and the shifting was flawless, I still lowered it after though.
after several hundred miles, the shifts are still perfect, not one mishift let alone a dropped chain.
Seat post is off my old aluminium Giant TCR. By coincidence when jammed to it’s max lowest position it fit’s my recommended seat height to the exact mm. I never have to worry about slippage since it can’t go any lower.
