The push up challenge thread got me thinking about pull ups. We have a bar in the basement, but I can’t even do one.
What’s the best complementary exercises to get started? Should I just keep doing negatives until I’m strong enough to pull up?
How long is this going to take? I’m currently 10-ish pounds over my “happy weight” and I haven’t been working out much and definitely not doing any strength work.
Negatives and just simply hanging there with straight arms would help. Also I would guess that chin ups target much of the same muscles and are much easier IMO.
Try to do these things multiple times throughout the day at 50% of your max effort vs making it a work out event. It’s the “grease the groove” methodology I linked in the push up thread. Check that out if you have a minute or two.
+1…should have included this as well since getting started bouldering is what made me realize I needed to seriously build up some vertical pulling strength.
Jump up to the bar and hold yourself in the finish position of a pull up. Slowly, sloowwllyyy, lower yourself down until you’re at the starting position.
Jump up again and hold yourself at the bar, rinse and repeat.
Even when I do regular pull ups, once I’m tapped out, I’ll do a few more negatives to really feel the burn.
Jumping up to the bar and landing in a finish position sounds harder than a pull up to me. Short person problems and all… but maybe I will get a chair and try this when I cache out after only a few pull ups.
+2 on climbing. I got into it for a year or so, and significantly improved upper body and grip strength compared with my tri-related training. It’s fun too!
