Tape vs. glue
I just got my new zipp 909’s today from 2wheeldeals. My question is for those that have used both glue and tape. Which do you prefer and why? Are there any problem you have encountered that made you switch to the other? Thanks.
i like tape. glue drys up and one day when it was windy my hair blew right off!!!
i like glue, never tried the tape though. Panaracer or Continental glue, don’t go near that hutchinson stuff…
Tape is super nice. No fuss, no muss. Plus it is much easier to center the tire, so you get a truer mount.
Used both: Panaracer cement on my current Conti Sprinters on Zipp 404s and previous Tufo tape on Tufo S3 on Hed3s.
Glue method is much better overall. It takes a bit more work to do it properly (like 24 hours), but seems much stronger. The tape melts too easy on hot days and makes a real mess of the brakes/braking surface.
I thought the glue was a pain too, so I tried the tape. Might as well learn from my mistake - I definitely recommend the glue method, as much of a PITA as it is.
Tufos are easier to mount to the 909s than Contis, but I use Conti glue (and Comps), works well
Tape is easier to use but dosent give anywhere near the bond of glue (even Tufo Extreme). Have done more experimentation than is healthy with both and would definitely only use glue from now on - for something that is as important as keeping your tyres attached to your wheels it is the safe bet.
I have used neither.
But a question for j3: if glue is much stronger than tape (I assume tufo extreme tape), why do other folks say that “taped” tubulars are much harder than glued tubulars to remove by hand from a rim, like when you flat?
Congrats on getting a great wheelset! I raced on mine the first time on Halloween - awesome!
I haven’t used glue or tubulars in 12 years. I used Tufo extreme tape a few weeks ago. Super easy to use - and center tire - clean and painless. Seems quite strong. My issues are this:
If you remove the tubular - my understanding (which could be wrong) is that the tape should stay with the tubular. The tubular is now ruined. You can’t remount it. Now lets say you get a flat - what is your plan? If you want to mount a spare tubular - you need to carry tape and go through that process (takes too long). If you use sealant or carry no spare - then maybe tape is an option. If you want to carry a spare - I think you’ll have to use glue. Sealant has issues too - its hard to get in the disc once the tubular is mounted (you need to use a syringe/catheter or bent needle). I also had trouble putting sealant in through the valve extender on my 404 front - don’t know why but I couldn’t do it. With glue - you can peel the tubular off and re-glue…
Also with 909’s - remember that your front needs a valve extender (I used Tufo’s 40 mm extender I think - not Zipps as Tufo’s is a core extender and seems more reliable re: leaks and with Tufo’s - no need to use plumber’s tape). I didn’t have any disc experience - so I didn’t anticipate that my CO2 adapter wouldn’t fit in the cut-out…
Remember that if you do carry a spare - then you’ll need to switch the core extender over if your front flats but not your disc - so carry that handy little care extender wrench.
Dave
My number 1 recomendation is that if you go with glue you get someone who’s done it before to show you how much glue to put on - otherwise you’ll think of Beloki the whole time and end up with a tire that is glued on so tight you’ll get blisters on your thumbs trying to get it off…
it’s not hard to put the right amount of glue on, but without knowing how much that is you’ll probably use too much…
also remember to leave about an inch unglued if you are using the wheels as race wheels as that gives you a place to start from to pull them off (and it’s much easier that way) if you flat in a race.
Dave - nice post! You “can” remount a tubular with glue, but it’s a pain in the ass. So, yes…go with glue on your spare.
As for Glue V. Tape…they both have different applications.
Glue dries, Tape does not.
Therefore…if you were making a progressive high speed rounded turn…I’d be much more comfortable on glue. It will hold where tape may be inclined to roll.
However, if I hit a bump while rounding that turn…the glue could “break” whereas the glue is more elastic.
Don’t tkae that example so literally…but that’s the basic difference. If triathlon purposed, glue is awesome…super quick, easy, dumby proof and reliable. In a perfect world, I’d still glue my tubulars…but the world isn’t so perfect.
Use the glue. It is messier to install but works far better. I was in a very hilly race last spring, and found that the tape melted, leaked out, and made a total mess of my braking surfaces and brake pads. I presume it would be fine if you were only racing flats…it worked great for me until I actually had to do some serious braking.
Phil
I love the glue ! It’s all about the smell. HA HA I think you would be better off with the glue if you did flat in a race. Just pre stretch the tires on the rims before you make the mess with the glue. I use kerosene (lamp oil ) to cleen up the mess. Enjoy your new stuff.
Dirt
Thanks everybody and you too Dave, your’s was very insightful. Both of my buddies use glue and have raced on them for several years. I only asked about the glue because it was suppose to be better. A lot of my tri races are rather hilly and I do not want to make a mess, so I think glue is the way to go.
i used to be a fan of the tape, here’s why;
*easy to mount and center
*could ride immidiatly after mounting
*it’s hard to screw up
I am no longer a fan of the tape, here’s why;
*Tufo lied to me about being able to safely reuse a taped tire; you can’t safely reuse a taped tire once it is removed from a wheel.
*The stuff turns to butter in the heat (this observed through personal experience with a taped tire, i wouldn’t dream of riding a taped tire when the temp was above 85).
*It’s really not that hard to glue a tire anyway, and with each succesfully glued tire, your self esttem rises that much more.
TUFO has addressed the heat issue and now has an “extreme” version of their tape for hot conditions. I used it in IMMOOO in 85 degree temp and Hawaii and it worked great. Absolutely no problems.
The tape is far easier to install than glue, not that glueing is all that hard, it’s just a bit messy no matter how carefull you are. The tape is ridiculously easy to install and center.
I’ll never glue again.
I also have used both. I think the “extreme” tape is the way to go. I also carry a small pair of trauma scissors for easy tire removal.
The wife got me a set of 404’s for x-mas. I’m about to order some tires and glue is there anything else I need?
I was going to have the LBD do but they said they didnt do it so I went to a second and they said they wanted $50 per wheel! So guess I’ll ask around or do it myself.
Dave
anyone know about what’s best for Vittoria Cors Evo CX tyres? I have both the glue (Vittoria Mastik One) and the Tufo tape…have never used tubulars, let alone stuck some on a wheel…glue or taps for these tyres?
I use the TAPE. I also carry a pre-glued spare. When the tire flats, rip off the flat tire along with the tape. The pre-glued spare on a lightly pre-glued rim will be more then enough to get you home safe. Very fast way to change over a flat tubular!
