Tall ski bend extensions
I know this has been asked before, but not sure I ever saw a good answer. looking for taller ski bends to mount shifters higher. don’t want to flip bars and have to drill slots for internal cable routing(DA mech group)
any ideas? I believe it needs to be 22.2 to fit aduro(3T)
Bontrager ski bend bars are my favourite, I think they will work for you mate
This is one of those things you’d almost be better off having custom cut/bent.
That said, the 3T ones can be reverse mounted to get a very steep bend, although they won’t have a lot of reach.
Profile design use to make one that had significant bends up. I think the Carbon Stryke or T1.
I use those as well on my SC7.5. Although I cut my down, and will probably cut another 1/2" off here soon. I most just prefer the wrist angle, but have smaller hands so I don’t need all that height.
I have had some trouble getting custom extension made. Do you have a good source? There guy I found is a little on the flakey side and I am looking to get a fancier set made.
check out my profile pic of my trek. Zipp carbon ski bends.
I did some measuring to see where I fall, and on stock aduro bars in low config, the top of mech shift levers appear to already be uci illegal at 10.5-11cm above pads so no point in doing anything in the event I attend an event where they check this. already have to tweak armrests to get into compliance with 10cm rule
