Tacx I-Magic Users
does anyone out there know how to just spin on the trainer at a consistent grade incline?? I want to do power intervals and need resistence w/o going up and down hills and staying on course.
I use the Catalyst program which I keep on the grade setting. Just set to the grade adn do my intervals.
Use Catalyst and then ride by slope. You can create planned courses or use free slope. Free slope will allow you to adjust slope/resistance on the fly. Also free power works similarly.
I’ve had a hard time using the HR and power programs unless I’m just doing a recovery ride.
when i try to select catalyst from the main menu, the program/application does NOTHING!! any ideas??
I’ve only just started using my i-Magic, so I’m no expert, which is why I lean heavily on the very helpful people on the Tacx forum - http://www.tacxvr.com/phpbb2/index.php?sid=109cfcf28cd959bd1f1fbc43215e8415
Hope this helps -
Same thing happens to me. . .if you find an answer please let me know.
In the mean time if you really want to you can run the test program and set the resistence to low medium or high.
Go to the Tacx forum and then I think the software forum. You should be able to find an answer there and a link to the drivers.
Make sure you have the latest drivers. It is a finicky product when you first set it up, but once running it works pretty well.
