Syntace SL Replacement Bolts?
I don’t think I ever met a bolt I couldn’t strip…where do you get replacement bolts? I tried the Syntace website but since I don’t read German…
I’d like to keep a few in stock for my aerobar clamp bolts, elbow pad bolts, etc.
Is there a source for bolts or do you all just go to Home Depot and try to find a good match?
Thanks!
If that’s a standard 6mm bolt, check with your LBS. Also, I see them advertised all the time on Ebay. Buy some extras and if you buy titanium be sure to put some anti-seize compound on them if they are going into a piece of aluminum. (Or at least some grease until you get the anti-seize compound.)
-Robert
At $2 a gram, these have got to make you go faster.
Yeah - I saw those! When I get to the point where I worry more about shaving grams then strengthening these weak legs of mine I’ll think about it!
