Switching aerobars...DIY project or LBS?
I’m switching aerobars and am thinking about trying it myself…any thoughts on overall difficullty? I am pretty confident that I can install the new bars as per specs and to the right configuration/fit. The brake levers should be a snap as I won’t need to change their length. The only thing I am concerned about is the 10spd DA bar end shifters. Anyone have any insight on step by step what I need to do? I searched Shimano but couldn’t find what I needed. I will need to shorten the cables quite a bit with my new configuration. I really don’t want to get new cables…these maybe have 300 miles on them.
Thanks in advance.
The bars themselves should be easy. You should probably use a torque wrench to avoid overtightening any bolts. As far as the the cables and housing, you will need to disconnect the cable from both deraillers, (that is the end you cut from), trim to length and then put on new end caps. Overall this is not hard, but the deraillers will probably need to be adjusted after. This job is all about attention to detail; you will probably make a few mistakes, but nothing a tune up couldn’t fix, so I say go for it.
I follow the shortening of the cables at the derailleurs - This may take a little work. They run through my Dual…any tips on that? Or do you just give er the ol’ push/pull method?
Follow up question:
How do you loosen the shifters enough to get them out of the old bar?
http://www.shimano.com.au/media/cycling/techdocs/en/bikecomponents/SL/SI-6J60A_v1_m56577569830536829.pdf
theres the installation manual for the da 10 shifters,
hopefully that helps you out a little
Once you take off the bolt on the cable at the derailler attachment, you sould be able to pull it right out of the housing throught the shifters. I would leave as much of the housing in place as you can, just remove and trim the short piece of housing between the shifters and the cable stop/entry where it the cable threads into the frame. Once the new bars and shifters are mounted just thread the cable back through the housing and attach to the derailler mount and trim the extra cable. Make sure you put on new end caps so the cable end does not fray (or cut you)
Maybe I’m missing something…but if I am going from bars without internal wiring of the shifters…to ones with internal wiring. Do I pull the entire cable out starting from the derailleurs and then re-route them through the new bars (all while leaving the the shifters connected)?
Is rewiring the shifters more difficult than the above?
Thanks.
The shifter cable has a stop on one end (this is how the shifter mechanism couples with the cable), so you can only pull it out through the shifter, not the other way around. Likewise you can only feed it in the opposite way, as you need to feed the end without the stop on into the housing.
Running the cables through the dual is surprisingly easy to do.
The first time I changed mine out, I pulled them out without thinking and then thought to myself “oh shit - shoulda fished something through there”. I was anticipating that several boxes of patience would be required but in actuality it was quick and painless. Just check and make sure that you understand how each cable should route and make sure when you put things back together that you route the cable housing at the shifter end such that it routes out of the aerobar and then goes cleanly into the frame without a dramatic bend in either place.
hey Miranda - hows it going? Signed up for next year or will we be seeing you at the bike races?
Simon
WAAY too chicken to bike race!
I’m doing First half, maybe UBC, IMAZ, Oliver, Osoyoos, Drummondville and then IMC.
Onwards and upwards!
… and yourself? Did you sign up for IMC? I’m sure you told me in August but I was a little out of it at the time :wink:
Really…if you are even a bit handy…save the cash and invest in the future…do it and learn…its not like you are adjusting a carb on an old Corvette…
imho
no IMC not even IM I am retired unless its somewhere exotic with lots of semi naked women hanging round the beach afterwards, even then it might be a stretch to get me to run :slight_smile: I am too slow and unmotivated but might race a few crits in the summer!
Good luck with all the races, sounds like hard work to me! :slight_smile:
