Switch the Bebops to _________?
Things are pretty scarce on the Bebop supply side. I understand a distributor has been named but I have seen nothing at the retail end. Any definitive word on when product will be available? I’m down to one complete set and would rather make the switch over to a new system in the coming weeks, then wait till Spring. If you’ve switched from Bebops which system did you go with and how do they compare?
I had a set of Bebops a long long time ago and didnt like the way they felt and went back to Time. Same gig with Speedplay too…
Eggbeaters. Would never go back to anything else. They’re incredibly light, reliable, hassle free, and the more you pull up the more retention you have. You’ll never pull out under hard efforts. They’re also fully servicable and rebuildable, so you’ll never be down a set.
I have egg beaters on my 29er and have pulled out. I am not such a fan of them.
You must have twisted out…it’s mechanically impossible with that design to pull out - you’d have to snap the cleat in two. Because of the 4-sided design, pulling up actually makes the spring clamp down even tighter on the cleat. That’s what makes them such a reliable MTB and cross pedal - absolute confidence when clearing obstacles.
I’ve raced xc on them for years, and now have them on my road and tri bikes…unbelievable reliability. Such a simple design, and so easy to get in/out of durng an xc race.
I’ve got two pairs of Bebops and am not planning on switching.
For my new commuter, I put Eggbeaters on as I needed cleats that totally recessed into an MTB shoe sole.
I hear there will be a new Speedplay MTB pedal coming out, maybe in the spring, which will complement the Frog but not replace it, sort of like the Zeros did not replace the X’s. If you’re on the Bebops because of the free float, I’d give them a call and see if they’re close enough to estimate a ship date.
Who’s the Bebop distributor?
Rocksteady!
I think Seattle Bike Supply is the distributor. Any bike shop with an SBS account should be able to order them (if they’re available.)
GG, picked up a pair of the Egg Beaters and did a test ride and ding-ding-ding I think we have a winner. The platform feels larger than the Bebops and with maybe a bit better power transfer. Less float than the Bebops but I didn’t need 20 degrees anyway. Seemed like there are several ways to clip in and I really like the ability to rotate the heel towards the bike to get out. They look fairly easy to rebuild and maintain. Inexpensive as well. Jury will still be out till we put in the long rides and hit the hills but they look very promising. Thanks for the tip!
