it’s been a decade since i last swam competitively.
anyway, since highschool i’ve done a half-dozen tris as x-training for something else, swimming on the back of old skill and present bike and run fitness. i tend to get out of the water in the upper 1/3 of my ag’s.
I got in the pool for a workout for the first time in ages last night. it was a shock, to say the least.
my balance is shot, my catch is soft and my memory of drills is softer. questions:
some balance drills? my left arm dominates - i breathe easily to my right and have a good left arm pattern, but i lift up while attempting to breathe to the left.
stroke pattern drills? my right arm has a mind of its own. i know what it should do, but i watch as there’s a wierd “sculling” going on in the first 3rd of my right arms’ pull. Thoughts??
i limped through 1600m last night… more than doubling my swim volume from 2004!! (two sprint tris)
What i was told to do to learn balance was to get a kick board…Lay on it with it under your chest (in the pool) with your arms stretche out past your head and work at having the back of your head, shoulders, butt, and heels dry.
Tell me about it. I stopped swimming senior year in high school and this is the first time I’ve considered competing since (26yrs old). Coming up to my first tri season this year.
First time I got back in the pool to train was painful, and pathetic. I had the same problem, balance gone, catch a joke, basically technique all gone to hell. I just thought to myself “this is going to take some serious work”. I don’t have a coach so have been figuring it out for myself again. It all comes back, that’s the good news, the bad news is it takes a while (for me at least). Increasing volume helped me a bunch - nothing like putting the laps in to sort those problems out. I recently discovered ‘Fistgloves’ (wish I had those from day 1) which I use 2 x week. Once for warm-up only and once for 30mins. I really like them. They help with balance (I think) and will probably sort out that sculling problem you have. Worth $9 IMHO.
Hey brother, I am/was in the same boat. I did a handful of sprint tris with no swim training. Also took a decade off since HS and now in serious training.
The only problem with what the last poster said (for me at least) is that it does no good if form comes back if your form suuuucked before. I was a competitive breastroker, and dabbled in butterfly, but a retriever doing his dog paddle had better form than my free. I was like a helix, the lower half of my body was twisting/going in a different direction than my top torso.
I don’t know your history, but I saw the decade break as a means of a way to ‘reprogram’ my form and get rid of the bad habits once and for all. Sure, you never forget how to swim, but I think you can definitely hone skills and get rid of bad habits.
First, watch those shoulders/rotator cuffs. If you’re getting back into the pool, relative weak shoulders + a driven workout regimine spells trouble. Take it easy.
Surprisingly, I recalled much of what my old coaches kept yelling at me to do: balance, look forward, keep stroke count to a minimum - all very similar to the supposed revolutionary Total Immersion (but thats another can or worms). Joe Fiel in his training bible book paraphrases well what has worked for me to achieve balance.
Starting out, I probably did about 80% of my yardage with that pull buoy between my legs, with and without pull paddles (again watch the shoulders). I personally found that more effective than drills b/c with the buoy, you know pretty quickly whether or not you’re balanced. Then just pile on the volume, slowly. Don’ know if this helps, but it helped for me.
As someone who started learning to swim at 39, just a few months ago, I say man up and ditch the notion of PBs and paddles. Those aren’t going to help your balance. If anything, they F it up. I may suck as a swimmer (I do), but I’ve learned basic balance by doing simple drills. Now PBs feel all wrong. It’s not my balance holding me back.
Start by doing some kicking without a board. Keep both arms in front of you and notice the flow of water under your arms. Breathe either to the side of straight up. Next swim using only one arm. Keep the other one fully extended. Breathe to the side of that arm. With both arms fully extended take one stroke, on recovery let your shoulder lead then elbow and hand last. Keep your fingers very close to the water. Your hand should enter the water in line with that shoulder and across from your opposite elbow. Glide your arm forward. Flex your wrist, start to open your HIP and take a breathe. It will seem like your are breathing early in the stroke. Repeat until you get to the end of the pool. Change arms and do the same sequence with your other arm.
After you feel comfortable with a one arm drill move to a catch-up drill. Be aware of your comfortable arm recovery (shoulder, elbow, then hand). Breathe on both sides for the drill. Feel the glide on both sides.
If you were a high school swimmer you probably have good ankle flexibility. Keep working on your kick to gain endurance and a strong base.
From your catch up drill start your stroke as soon as one hand enters the water opposite your elbow. Now you are into a faster stroke without the wait for full extension of both sides.
A very good way of knowing that you are doing the right thing is to first notice the hand entering the water on the non-breathing side before you take a breathe. One you can do that find that hand twice in each stroke cycle. You will see it as it enters the water before your breathe and then after you breathe that arm will have reached full extension - see it again before you pull it back.
You will never go back to the old way of swimming. View swimming as a new sport to be learned and enjoyed.
