I regularly get a bad headache when swimming longer sets (1000+). It builds up slowly, the longer I go the worse it gets.
I’m not particularly out of breath, so I don’t know that it’s a CO2 build-up issue.
Any tips on how to deal with this (other than swimming more long sets)?
make sure your goggles aren’t too tight.
As Tigerchik says, check your goggles…I’ve also had this from an ill-fitted swim cap. Otherwise, assuming that you don’t get this doing other exercise, are you hydrated etc?
Stop relying on your head to tell you when you reached the end of the pool?
I have had tons of issues with headaches when I swim. Mine sound similar–I’m ok if I do short intervals, but when I swim long sets or a long straight open swim I used to always get headaches. I tried the different goggles, but it didn’t matter.
My issue seems to be mostly resolved by fixing my head position. I was looking too far down the end of the lane and not at the bottom of the pool. That would create tension at the base of my skull/neck which would grow to a headache. Two things that helped me: 1) working on head position–relaxing my neck and looking down 2) seeing a chiropractor to better align my neck/head so that I could have my neck in a better position while swimming.
Good luck. It sucks having this dreadful feeling that you’re just waiting for the headache to start.
I would have to agree with ride’em. I read an article that putting a tennis ball under your chin when swimming will give you proper head alignment. I have never tried it but it sounds like it would work. I am going to a swim clinic this weekend and I could ask the coaches this question about the headaches.
Not tonight honey, I have a swimming headache.
I used to get headaches immediately after my swims. Now I take a water bottle to the pool. I sip between sets and I finish a full bottle after I’m done. No more headaches for me. This doesn’t sound like your problem, but I thought I’d offer it anyway just in case.
Dawn
lol!
Had the same problem.
Earplugs.
