My Masters coach challenged me last week to
learn flip turns. After over 10 years of swimming
I’d perfected the open turn to where I had a pretty
good one (if I do say so myself) and had no desire
to learn the flip turn.
that all ended last friday.
Now…I’m forcing myself to ‘do them’, no matter
how ugly, how much water I take in, etc. etc.
Not really getting much better (I know it’s only
been a week). I can do the somersault, but when I
do it close enough to the wall to get a push off -
I panic / freak out thinking I’m going to crack all
the 250+ bones in my feet and kind of bail out.
When I do it far enough from the wall (where that
lovely “T” is painted on the pool bottom), I’m OK :
but I want to progress farther.
Can anyone help here ???
thanks in advance
Dan Brown
p.s. I know that as a triathlete - they are not
that big of a deal (I never do any pool tris anymore), but for some sicck reason - I really want to learn them now (go figure).
At the age of 50 it is also my goal this winter to (re)learn to do a flip turn. I figure since I was getting down to 1:23 per 100 yd intervals, flip turns were in order. But for the life of me, when I practice in the middle of the lane, I can’t stop the flip at 180 degrees, and spin around 360 degrees ending up in the same direction and with a nose full of water. Hopeless?
Double post! How’d I do that?
As a good (non-flipping) friend of mine used to say a long time ago, “Lakes don’t have walls.”
From what I have observed, most people that do flip turns incorrect, are tucking too much. They almost look like they are doing a flip off the diving board. This causes people to be too close or too far from the wall. Some tips on what a good flip turn is like…I’m not an expert, but did swim my way through college
-when your feet are on the wall, you should not be curled in a ball. You should be in a “crouch” position.
-most people use their arms too much, out by their sides and all kinds of waving around. Pull hands down to the hips when doing into the wall, push down to start the hips up…now think of the hands staying stationary, and the body rotating around them
-your feet shoud hit the wall at the X, not above or below. When your feet hit about the X, thats when you have to worry about hitting them on the edge…OUCH!
-Always always always, blow bubbles with you nose. Nothing worse then water up the nose on a flip turn!
-Next time you do 25s or 50s, start in the middle of the pool. Its a good way to practice turns without setting time asside for them. Just integrate them right into the workout
Flips turns can be intimidating. If you can do a forward roll in the pool you can master it. Turns are done my driving your head down and moving your hips forward. The line on the bottom of the pool near the wall is five feet from the wall. You will need one or two strokes before you initiate your turn. As you swim into the wall bring your arms down to your thighs, look at the wall (so that you know you are close enough) for a split second (do not take your head out of the water). Drive you head down to your knees and SEE them. At this point your knees are only slightly bend. You are now upside down with your legs on the surface and your head near your knees. You will feel a stretch in your hamstrings - bend your knees and throw your feet to the wall. You are now on your back (feet pointing toward the ceiling), knees bent 90 degrees. Push off the wall and skewer toward your stomach.
A great way to practice the turn is to stay on your back as you push off the wall. Work on turning over after you have master the turn. Always finish on your back.
Watch some of the swimmers who have really good turns. Pretend you are one of them.
There was another comment about hands - yes they do not move, you body is pulled toward them. As you push off your arms WILL be overhead and fully extended.
i disagree slightly with what has been said about hand position. as you start the turn, they’re right, your hands should be down near your hips. but rather than just leaving them there limp, you can pull them toward your head (kind of using the same motion as when doing biceps curls, but don’t keep your elbows at your side and then just continue the motion up over your head) to pull your body through the flip. then they’re where they need to be for the streamline. also, a lot of the beginning flip-turners i see out there stay tucked through the whole thing. if you watch experienced swimmers, they open up the tuck well before their feet hit the wall. in fact, sometimes it looks like a pike position rather than a tuck. this keeps you from over-rotating.
One key that helped me finally “get it” was to keep my hands in the “palm up” rotation. Rather than a bicep curl you are doing sort of a forward raise motion, you should wind up upside down with your feet on the wall and your hands over your head in position for the glide. My tendancy before was to try and turn my hands down so I could grab more water to help with the flip, but then the hands come out wrong for the glide. Good flip turns finish with the push off upside down, weak ones tend to try and flip over to the stomach before or during the push off. Try transitioning from free into backstroke on the turn. I’m no fish but this has worked for me.
I’ve never been convinced that I need to do flip turns since I don’t compete in events where they are necessary. I do a variety of turns at the walls, often with one hand on the edge to help rotate me around quickly, and I always exhale before I turn, and inhale as I turn so that I’m not resting on the turn.
Oh yes I am also convinced that the damm flip turns I was fooling around with - just for fun- last summer caused my herniated disk… so now i have lost 6 weeks of training all because of my stupid impulse.
Rule- practice what you need to practice and don;t bother with useless stuff.
You are right. I did not want to complicate the turn by introducing the pressure on the hands. Your discription is quite accurate. When viewed from under water your hands do not seem to move. I feel as if I am puuling really hard with my hands and forearms.
