Ok i figure that i am not the only one who wears glasses. When i train to swim my goggles aren't prescription, I can't seem to find the style i like in scrip form, so i swim practically blind, unless you a giant blob of color. Should I get contacts? Can you even wear them in water? I just need to know how to see!?
What is there to see in a pool? You may be better off, you won’t have to witness the cottage cheese on the water aerobic ladies. You’re fine as long as you can see enough to tell where the pool ends.
I have the same problem, I don’t wear contacts and use prescription sunglasses for run/bike. What I did was buy speedo opticals. They are like $15-18 (if you look around on the internet) and you just buy one that’s closest to your degree.
aquagoggles.com Get the v1 model rather than v2 – at least that is what I like. They were on sale a while ago for about $15! I like to get prescription goggles a little weaker than my actual prescription.
I like to be able to see the clock and some of us are blind enough that it helps on turns also.
I wear my contacts under my goggles. Not a problem. Of course, I’m always already wearign them anyway.
-charles
