Sorry - my bad.
I was going to say that pads are a nuisance. I have found concentrating on using my whole forearm, and keeping my elbow high, I manage to ‘hold a lot’ (quote Gordo) more water, and hence get a better grab of it. Pads fool you into thinking you are holding heaps, but your hand alone does so little.
You nailed it! Pick your lingo- Hold, Catch, Grab, Pressure -it doesn’t matter the idea is the same, create the most amount of focused force possible per stroke. Why focused? Well there is no point in pushing water in a direction that does not move you forward. Paddles tend to do that, in a big way, if you are not very careful and precise with your motion under water. They can fool you into thinking you are really pressing hard and moving forward fast, when in fact you are only pressing hard and moving water in directions that are not beneficial. This creates bad habits in the form of poor stroke technique. It is my opinion that the weak (as in strength) swimmer who is efficient is better off in a Tri than the strong (as in strength) swimmer who is inefficient. I look at it as energy wasted, we all have a limited pool of energy to draw from and if we waste it thrashing around in the swim, there is in therory less to use on the bike and run.
Think of it this way, which car would you take in a 1 mile race?
#1- 100 HP, Good Tires on Pavement -same Body and weight as #2
#2 -400HP, Slicks on Ice- same body and weight as #1
I’d pick #1, even though it has one 1/4 the power, all of it’s power will be focused on moving it forward, making it more efficient and faster. #2 has a hell of a lot of potential, but is not using all that power wisely, it need to focus that power, by “getting off the ice” and getting better tires-think slipping your hand/arm through the water.
Paddles do have a place and a benefit for the swimmer who is experienced and very efficient with well rooted and establish stroke technique (ingrained). They are great at building strength and power, which will then translate into speed. But they are also great at nuking shoulders, due to the added pressure on the joint.
For above stated reasons it is VERY safe to say that almost every triathlete has no use for paddles! Keep using those Pull Bouys!
