Swim Workouts to Improve Pace @ Longer Distances
Sorry if this doesn’t come out right but what I’d like to find out is what some suggested workouts are to enable holding or improving T-Pace at longer distances. 300, 400, 500, etc.
I have the common problem where I’m sharp at shorter distances and able to improve those times but when it gets longer, I trail off.
You could do a number of combinations of hundreds, but i’ll give you some examples, i’ve done recently…And just try to swim fast, but being able to maintain the same speed throughout the workout. (around 1000-1500/1650 race pace for most of these)
4x800
1st is straight, 2nd is broken by 15 secs at the 400, 3rd is broken by 10 secs every 200, 4th is broken by 5 secs every 100. Keep the interval for each 800 the same and try to get your time for finishing the 800’s similar.
3x300 100ez 3x300 100ez 3x300 100ez
4x50 descend 1-4, 4x100 pace, 4x150 pl, 4x100 pace, 4x50 descend 1-4
8x200 on said interval and drop the interval 5 secs every 2
24x50 on said interval dropping the interval by 2.5 secs every 6
5x100, 4x200, 3x300, 2x400, 1x500 for time
broken 2000 by 15 secs
800(get 600 split), 600 (faster then 600 split, get 400 split), 400 (faster then 400 split, get 200 split), 200(faster then 200 split)
4x1500
#1 straight #2 15x100 pace #3 3x500 descend #4 all out (try to go faster then 1st)
TJ
Trying swimming your shorter intervals at your desired pace, but keep the rest interval very short, under 10 seconds.
For example, if your threshold pace is 1:20, try swimming a set like 6 x 100 on 1:25 or 1:30. As you get stronger, lengthen the set to 10 x 100. OR swim a broken set like 4 x (4 x 100 on 1:25) with 30 seconds between sets.
As you become stronger and more able to swim at your desired pace with very little rest, start to lengthen your intervals to 200, 300 or 400s.
here is one;
after warm up and drill set you do 800s :30, 8x50 fast :15, 600s :30, 6x100 fast ;15, 400s :30, :4x150 fast :15. 100ez then 20x25 sprint :20.
100/200/300/400/500/400/300/200/100 on race pace + :10/100 (SCY). I did this holding exactly 1:10s on 1:20/100, and did a Oly relay swim in 18:54 (just about 1:10/100).
