Swim question?
I’ve seen a little on this, but not too much. Whenever I spend more then about 20 minutes in the pool, I am completely dead. Its different then if I am on the bike or go for a run and just kill myself. I am new to swimming, about 8 months. But, whenever I get out of the water, about 30-40 minutes later I just feel like I have to go to sleep, it doesn’t matter what time of the day it is. I spent about 40 minutes in the pool today and took a 2 hour nap in the middle of the day when I got done. I don’t ever feel sore when I am done, just really tired. I am wondering if it has such an impact on me because of my body fat and being in the water? The water in my pool isn’t too bad, its about 76 I believe. Just curious if I am the only one out there.
I had this when I first started swimming. I just kept at it, and it went away. Seems like level of swimming fitness issue.
Great question!
I have had people explain this to me on quite a few occasions. The issue is simply tension. Your observations are spot on. The workout would not be considered necessesarily LONG or HARD, but your energy output is extraordinary. You are recruiting too many muscles to accomplish the task and also asking too much of the ones you need. Try to become aware of the “clinching” you are doing while swimming. It normally manifests itself in the upper chest (breathing issue), jaw and hips/lowback/glutes. Once you notice some of this, try to ‘release’ the effected area and also work on getting a sense of what kind of support the water will provide you. Keep me posted.
All the best,
daved
you may be winded and wiped out due to using new muscles in the pool. and yes, poor techinique in the pool also equates to wasting energy in the pool which causes more fatigue. depending on where you live, you may want to seek out a private swim coach to help you with your technique.
and as you get better at swimming, it will get easier and you will also get less exhausted. swimming is the one sport that technique is everything. you can get away with poor form in both running and biking, but the water is totally unforgiving in that regard.
good luck!
joanna in philadelphia
personal swim and nutrition coach
www.nutrition-in-motion.net
No, you’re not the only one. When I began swimming last year I had decent cardio fitness from running and cycling and also had decent upper body strength from rock climbing and weight lifting. Yet, swimming even relatively short distances left me exhausted. Time spent in the pool, plus a coach, gradually improved things – probably a combination of technique, being more relaxed in the water and maybe some sport-specific muscle improvements. I am still somewhat slow (between MOP and BOP out of the water in most races), but I can swim a mile or more with a wetsuit without getting too tired.
