Swim -> Lift OR Lift -> Swim
Heading to the gym - should I swim first then do my weight training or vice versa? Just looking for discussion (pros/cons) of each. I’m inclined to swim first - get the most out of it - then get any residual effect while weight training.
When I was in college, we always swam first and lifted after. I’ve heard some people say to lift first, but I think that might promote sloppy form and less of an aerobic workout due to being overly tired.
Skip the swim: save your energy for the gym.
The swim will get you nice and loose for the lifting. Personally, I don’t really lift weights…ever…I do dryland exercises that are very specific to the types of movements needed in a tri. So take that for what it is worth.
Are you training for weight lifting or training for swimming?
jaretj
When I was in college, we lifted first and then swam. The first 1000 or 2000 was a real struggle because of the tightness, but eventually, you loosen up and everything is fine.
Just doing base work - which I’ve always heard involves some off-season weight training. If time was not an issue - I’d just do one … but such is life. Got this whole job thing :slight_smile:
Depends on what your lifting and what your swim workout is going to be. If you’re planning on lifting shoulders, I’d say swim first as you’ll be too tired to maintain form effectively, thus wasting the workout in the pool. If you’re doing legs or something, then do whatever you want. Just don’t lift shoulders before swimming, really.
I suppose this could be different for everyone, but that’s the way it’s worked for me.
Kinda depends on what your sessions for each look like. Generally speaking, fine motor control and explosive power are the first things to go with fatigue, so if you’re doing a sprint session in the pool, swim first. If you’re doing olympic lifts, lift first.
Personally, I prefer to lift first - poor technique due to fatigue while swimming is sub-optimal, but poor technique while lifting can seriously injure you.
I lift then swim. I am not lifting huge weights, just doing lots of light reps for injury prevention. Then I swim with lots of drills and form work. I save the speed day or long swim day for later in the week.
This is kind of an all over weight training session - low weight, high reps (injury prevention) hit most body parts (relative to triathlons). Swimming is drills/practice.
Yep. That sounds like what I do twice a week. It really has helped me feel better overall. (the other weight session has a bike drill session with it single leg drills and high cadence work.)
I read an article somewhere talking about how people go to the gym and do all these machines and reps and can;t even do a push up or pull up. So, I have incorporated that into my routine and found that my strength has inreased more rapidly than with weights alone.
if its a hard swim day, i’d go swim first, then lift. But i personally (on one of my 5-6 swim days) lift upperbody first, then do an easy swim. This seems to facilitate the best active recovery, and reduces overall soreness the best for me. I also like to think that in a way, this helps to direct the rebuilding of the muscle in a slightly more swim specific fashion (no data behind this, just personal opinon).
Someone lied to you. Seriously. Skip the weights for 5-7 weeks and spend that extra time in the pool. You will be swimming much faster then if you lifted.
If your technique is sound enough, and solid enough that you can swim tired, and struggle to maintain it, then you can lift first, but of course it depends on your swim workout plan. If you struggle to find your technique when you aren’t tired, you may as well just lift and then go home, but don’t get in the pool tired, IMO. You will, at best, solidify your struggling technique, to steal someone else’s phrase.
spend the extra time swimming :smiley:
Hello B3booner and All,
I read an article about the Stanford Swim team a few years ago and their coach had them lift first, then swim, but it was contrary to conventional wisdom of the times.
Also as I recall they were having a winning season.
Cheers,
Neal
when have they not had a successful season? For years, under Quick, Stanford was THE place to go swim at. Stanford could have beaten many countries in dual meets.
