I seem (so I’ve been told) have a rather weak/“runners” swim kick - most of the kick coming from the lower leg. It seems that a better - stronger kick comes from the upper leg also. I assume a person does not really want to do a stiff/straight legged kick - some kick from the lower leg should still be there. Does this assumption seem correct?
In an attempt to improve the total leg kick - what about (for only a few training miles once in while), putting those neoprene knee supports on the knees? the idea being to slightly stiffen the knee joint and try to get more of a total leg kick. or at the least, the mental image of slightly less movement of the knees. is that more like the kick should be?
try to kick in as small a motion as possible, keeping your toes in a small (6 inch) range of motion (as fast as possible). If you need help seeing what you are doing, kick vertically. When you kick, the motion is initiated from your hip, not your knee. However, your knee does bend slightly to enable a “whip crack” type motion at the end of the kick. If you have trouble keeping your legs straight, then pretend you are trying to kick with a solid leg (no knee). Quite likely you will balance out to something resembling the appropriate amount of knee bend.
kicking vertically with poor form will result in your having trouble breathing, so its good motivation/feedback
