Swim breathing to be fast?
For all the few years I have been swimming, I did 3 stroke breathing since I assumed this made one the fastest.
I read one post on ST that said the person 3 stroke in practice, but 2 stroked in races.
Well, I have found that with my 6 months of masters swimming, I no longer basically ever 3 stroke breath, it is always 2 stroke.
As I am not pushing the pace, there is no way I can 3 stroke breath and swim.
So, is this others experience that to swim fast one needs lots of fresh air so 2 stroke breathing is what has to be done?
Dave
Finally a swimming thread that is not about arms, legs, fewer strokes or kicking! Thanks.
Breathing is critical to performance. Rythm is one of the 4 top components of effective swimming feedback. Rythm can come from many areas (see list above) but also from breathing. A great exercise to increase your awareness is to just focus on the rate of breath that you are taking during one length of the pool. Then, climb out and walk along the length of the pool (trying) to breathe with that same rate/tempo. Most will find that they are hyperventilating before they are half way.
Our breathing rate is one method our system uses to judge danger and raise tension/protection reactions in the body. Breathing a full exhale and inhale every 2 strokes (or better said, UNDER one of your arms each time it is over the water) or about every 1 to 1.5 seconds is not effecient (or even possible really) and does not allow enough time for your system to have a quality exchange.
Breathing every 3 strokes (or alt breathing) does help to slow that down a notch and work on another component called symmetry. The ability to get a relaxed complete breath on both sides that is not disruptive to your rythm is nice to tool to have in your arsenal.
All the best,
DaveD
Check out most of the best swimmers, and you’ll see they breathe every stroke.
In a triathlon, that is…
Many of the top distance swimmers breathe every stroke. The longer your stroke, the more sense it makes to breathe every stroke.
When training I breathe every 3 strokes but racing i breathe 3-2-3-2 to get the extra air I need.
I can keep my pace up but have a good cadence at the same time.
Yep, one can have all the best technique in the world, but if you can not get air, you will slow down. I know I still practice breathing on both side for my 2 stroke air, but only do the 3,4,…9 stroke
stuff in some drills the coaches give us. The trick now is to find just the right effort to maximize my speed. I know the other day we did a 1000 and I tried real hard to keep constant 1:35 100yard swim splits. Once I got in the zone, I could hold it. But, if I pushed to hard, then I was never able to recover.
I am not sure I would have thought of this, or seen swimmers doing this if I had not read this on ST to get my thinking. Lots of great stuff to learn on ST. !! :o)
Dave
I have tried to train with 3 stroke, but I have to go slower if I want to keep that pattern.
How do you swim full out in drills and hold a 3 stroke pattern? Would a full out 2 make you faster?
Dave
you’re expecting people to do 2 strokes in 1-1,5sec. That’s 90-120 strokes per minute, which is highly unrealistic for even the best swimmers in the world. In reality, elite swimmers are doing closer to 70-80 strokes per minute. Breathing every 2 strokes allows for one breath every ~1.5sec, which is great. now look at the MOP triathlete doing <60strokes per minute. breathing every 3 strokes becomes one breath every 2 seconds, and at race pace this becomes a bit difficult if you have to make the occasional big surge. Then look at the BOP triathlete doing a measly 40 strokes per minute. This becomes one breath every 3 seconds! Anyway you get the idea i guess. So it really depends on your turnover rate to see what’s best for you. Nevertheless, it’s important to be able to breathe bilaterally i agree, to be able to adapt to wave conditions, sun conditions etc.
Try thinking of breathing as a TECHNIQUE instead of just what your arms and legs are doing. Maybe that will help. I have had amazing experiences just sitting back and observing my breathing. During the hour swim that I did recently, I noticed that if I took away the rules and just breathed when I ‘needed’ it and not prescribe to every stroke or 3 or 5 etc…I was able to increase my pace. I averaged about 107/100yds for the hour.
The point is, I would sometimes breathe 3 times in a row under one arm (or once every cycle) and then there were times where I would go 6 strokes or 8 without. Then 2 in a row, then every 4th for a while…etc…listening and feeling what my body was and was not asking for in terms of air, allowed me to swim faster and be more effecient vs me dictating when I SHOULD be breathing…
all the best,
daved
this thread will answer every question you could have about breathing (and questions you don’t have). the bottom line: the vast majority of elite distance swimmers (that includes elite triathletes) breath every stroke (i.e., every two, same side, whatever you want to call it) during high-speed training and racing.
but nearly all the good ones can breath every stroke from either side.
http://forum.slowtwitch.com/gforum.cgi?do=post_view_flat;post=1108687;page=1;mh=-1;;sb=post_latest_reply;so=ASC
In general, it’s best to breath every 3 for the balance and form benefits. However, as you increase your effort, your body will demand more oxygen and at some point it will become more beneficial to to breath more frequently.
I use breathing as a gauge of my fatigue. If I can sustain breathing every 3 i know I can maintain that pace for a long time. If I’m alternating between 3 and 2, I’m pushing hard enough that I’m starting to go anaerobic, but by breathing more frequently I’m trying to stay aerobic. I can also sustain this pace, but it takes more concentration. This is the pace I like to maintain during a race. If I’m having to breath every 2 consistently I know that I’m not pacing well and that I need to slow down.
Interesting that you bring up this subject. I have been touted it for a long time and feel like I am swimming upstream.
I swam competitively most of my life. I was a short course USS swimmer and 3 - 5 -7 stroke counts were common before breathing depending upon the distance. This is pretty common.
By rule when I swim I do 3 stroke counts when I do an endurance swim. I never go hypoxic.
When doing tempo or race pace I also do 3 stroke counts, but I go hypoxic usually in the last 100 if I am doing a 500 meter interval.
When I race I do 2 stroke counts. Going hypoxic is not an option when racing and the only way I can keep my race pace is by doing 2 stroke counts. It’s my believe that people who adopt short course breathing in endurance swimming are just robots who read these swim books and think they should breathe every 3 strokes. Sure look a Thorpe… well Thorpe isn’t swimming 1500 meters much less 2.4 miles.
Key is to breathe when you need to. I think too many swimmers need to slow down because of their rythym breathing which is causing their hypoxia.
Now I will switch sides. My stroke count is 15 for 25 meters and at the pool when I am doing 2 counts I switch sides so it comes almost naturally to me in a race. Sometimes it’s even a good distraction to count during the race plus it makes you focus on your breathing.
Dave
I think you need to find what works for you. As a general rule, in all distance sets/events (in a 25yd pool), I breath 2 (off the turn)-3-3-4-2. At the end of a distance race, typically that breaks down to 2-3-3-2-2…
I’ve found that some alternate side breathing in a distance race situation gives me something to focus on and keeps me from thrashing towards the end. I try to use the same basic strategy in open water swims, usually 3-3-2-2-3-3-2-2…
This all might be because I was alternate side breathing since I was a kid.
-Nick
I work with stroke rate, not cycle rate when I calculate those times. So, take a look (as mentioned on every swimming thread) the best swimmers. Distance swimmers and FOP triathletes. Their stroke rates are .7 to .75. That is the time between hand hits. So two hand hits is one cycle or approx 1.5 seconds. I was a bit quick with the 1 measurement, sorry. Long day so far. But set a tempo trainer to beep at you every 1.4 or 1.5 seconds and breathe at that rate. You will notice that is a bit too fast for a quality exchange, even with an elevated HR.
It does not matter if you are FOP, MOP or BOP swimmer, your breathing needs should NOT be dictated by your stroke rate or turnover, rather your need. That need can only be assesed by playing with your QUALITY of breath and discovering how different your breathing can be (feel).
Great feeback though. Sorry again about being off a bit…ugh…
All the best,
daved
In training I’m more focused on form. The speed comes from a great foundation of form where you can cover more distance with less strokes
When I go straight 2 stroke breathing I find I don’t get as much hip/torso rotation so my shoulders get burned out.
I’m trying to get to the point where I can race with breathing every 3 strokes as I feel it is easier on my body that way and I can get better power transfer
I do the same. It does take practice to get to 3 strokes per breath. I find it a great benefit racing to be able to breath on both sides. I can breath away from a thrasher and I can also use landmarks and the sun to go straighter.
I still love to switch the side I breath on. Some times I need it per stroke to catch up. So, I change around depending on need now and what type of distance and speed
I am shooting for. It is nice to understand the difference and be ready to use whats needed in a race. I have a race this weekend where the swim will be 4 corners of the pool, I think 5 times around. I have never done this but since turns tend to be the roughest water, I am expecting a pretty physically swim, so really need to be able to breath when I get into these situations.
Dave
“but nearly all the good ones can breath every stroke from either side.”
Best answer yet! For open water swimming, one of the best skills you can have is being able to breath on either side. Blazing Sun, sighting, annoying freak who keeps staring at you when your breathing at the same time, ocean swells, whatever… you need to be able to switch sides breathing to account for any number of situations. If you don’t train to turn your head to the left, and you start having to quit staring at the sun that just rose to your right 1/2 mile into an irondistance swim, neck issues here you come (maybe/probably). I think that as you get into a race situation, your body tells you what it needs, and if that is breathing every 2 strokes, or every 5, if your body is used to it, you’ll probably be fast and have no consequences.
As said, top swimmers breathe every stroke cycle. Even 100 meter world class sprinters will breathe every stroke cycle after the first 25 meters.
One of the biggest errors in swimming is the timing of the breathing. Whether you breathe every third stroke or second stroke your breathe is taken in line and timed with your shoulder roll toward the beginning of your stroke. When done properly, your head should barely move.
When swimming at a moderate pace we do not exhale completely. This is the same as if you were going for a run or bike ride. As the pace picks up, the depth of your breath increases. Make sure you exhale in the water before you inhale. Hold your breathe until just before you turn to breathe. If you are constantly exhaling you are also constantly sinking.
dougStern
Doug, great inputs. I loved the last one to hold you breathe until just before the turn. Got to change to that.
Dave
