Suunto Memory Belt help!
I just got a replacement from the running store, and tested it out tonight.
After I finished, it has yet to stop beeping every thirty seconds or so. Aside from popping out the battery after every run, how do I shut it off?
Dont worry it will automatically shut off after so long.
After how long?
I just popped out the battery, but only after it beeped for about thirty minutes.
Mine would beep, I would go take a shower then by the time I would get back it was done. Have you tried to use it to upload the data? Maybe that will get it off sooner.
dry out the contacts really well and make sure you don’t put it with anything else sweaty.
The drier it is the quicker it will stop beeping.
Mine does beep a long time after the workout is over.
