it has Zeus Cat 3 Carbon Handlebar (the one with the flat top). Since the top bar is flat, my old John Cobb designed slam bars won’t fit it–does anyone know what aerobars will fit that flat top?
I don’t reco you attache clip on’s to the flat section (if you can find one that will fit).
You could probably use the round section where it is fortified for the stem.
I tried this before on my FSA K-wing.
There was little space left outside of the stem clamp so I had to slightly shave the clamps of my Profiles.
Worked well with but was too crowded in the stem portion.
I would recommend something from Oval Concepts where you can attach the aerobar extensions to the stem face plate. You’ll need a new stem in addition to the extensions but it would allow you to use your current handlebars. Slowman wrote an article about the bars a while back.
