Subaru Forester
Has anyone here ever changed the brake light bulb on a Subaru Forester? Is it just the bulb that needs replacing or is it the entire brake light assembly? Brake light is on the passenger side.
thanks-
FP
There is a panel on the back of the light assembly inside the cargo area that is accessed and then you can replace the bulb. Once you see it it’ll be easy. Open the tailgate and look at the side you need to replace. Pull the little panel off and you’ll see the back of the bulbs.
The headlights are just bulb replacements as well should the need arise. Good luck.
What is it with you and lights on vehicles this week?
