Stuck in the Lavendar Room
Does anyone else notice when you are viewing a thread in the Lavendar Room, if you use the “Jump to Forum” button and click on “Triathlon Forum” it just brings you back to the front page of the Lavendar Room?
Then when you doing it again it takes you to the Triathlon Forum.
Edit: The same thing happens in reverse as well. When viewing a thread if you try to jump to a forum it just brings you back the main page of the forum from which the thread you are viewing is in.
I think this post belongs in the lavendar room :slight_smile:
Unfortunately, this seems to be an unintended side effect of adding a “jump” button at the bottom of long threads, which people requested. I’ll remove that, and replace it with a “back to forum” button at the bottom, rather than a jump menu…
Ok, not trying to be a complainer, just figured you might want to be aware as I don’t know how it might effect other stuff.
Thanks.
Thanks. People generally seemed to use the jump buttons within threads to go back to the main forum. Jumping from a thread to another forum didn’t seem all that common, so I just forgot to test it. Thanks.
Yea, thanks!!
